![]() | Home > Td5 > Which Glow Plugs? Replacement TD5 glow plugs |
Since I have had no joy in the Miffy thread;
http://www.defender2.net/forum/topic53859-30.html I thought I would try a more direct approach. The back story is covered in more detail in the above thread, the shorter version is that after testing the plugs it would appear that none of them work and probably haven't done so for quite some time. Have to admit it is something I have been putting off due to the awkwardness of the glow plug position on the TD5 engine. But since the head is off getting pressure tested this is the time to replace them. Found this thread, but that was two years ago at least; http://www.defender2.net/forum/post486614.html So... Glow plugs. need a full set. what are the best ones to go for? LR NGK Bosch...??!!! I know very little about glow plugs, but have heard there are some big differences between brands, both in quality and operation. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6662 ![]() ![]() ![]() |
Not sure much has changed in two years as far as glow plugs go
![]() Stick to an OE manufacturer - NGK/Denso/Bosch etc - rather than the cheapest pattern ones. LR ones are only one of the above with the green oval tax applied ![]() ![]() ![]() |
Ha well you never know Martin, it is not long ago HID was the name in bright lights, now it is LED... Could've had a major breakthrough in glow plug tech so they glow hot quicker etc...
![]() DieselRX perhaps: http://www.dieselrxproducts.com/glow-plugs.php ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5938 ![]() ![]() ![]() |
I think mine are NGK ones. 1999 Defender TD5 110
Lwb97 Member Since: 10 Sep 2015 Location: Powys Posts: 76 ![]() ![]() ![]() |
Beru I think are OEM, that's what I've always removed anyway
HI Toby. Yes NGK for me as well in the end.
