Home > Maintenance & Modifications > Chassis Treatment DIY products |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
thanks so if i wanted to do POR 15 on first , how many cans you think to do the chassis and axles underneath which would look smart.
31st Oct 2017 2:08pm |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 917 |
Ohhh Don't quote me but 1 can has done 2 rear X passes, 2 x coats on the rock sliders, rear tow hitch and fuel filter cover. and there is still a bit left approx. 1/4 in a can so I would say 2 cans to do what you plan to. after all it is about £24 a can.
31st Oct 2017 4:41pm |
thanks , its the cost that puts me off and i may keep this process simple with the 2 products you used . I was originally thinking of using Fertan rust converter in the chassis as well but it all gets quite expensive.
Is the cavity wax clear btw? |
31st Oct 2017 4:51pm |
No the S50 is brown-ish.
I could of painted the whole underside but I didn't as it was going to waxed and as you said cost is a factor to some especially me. the Rear X is the visible bit so a nice strong paint coat is key to me. It is far cheaper to DIY then pay a dude to do it and being your own truck you take more care. I brought the Paint and masking stuff off ebay and the BH stuff came from Opie. the PPE was from local sources. |
31st Oct 2017 5:02pm |
Cheers bud for all the info, just wish I had a nice garage and lift like your self..
31st Oct 2017 8:34pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 666 |
Might be worth considering this if you are wanting to paint the chassis before hand:
https://www.tetrosylexpress.com/home/catal...TETTBL005- It is about £40 a tin. I have used it on trailers as well as my rear cross member with good results. Wish I had come across it before dynaxing my chassis. |
31st Oct 2017 9:11pm |
It is a friend of mines place and I reckon I could of done it on my neighbours drive (I don't have one let alone a garage) but the filming and creating a high (ish) quality production would of suffered. The job would of been done but there is no way the guide would of been any good. Just see my service guide as to how mother nature makes it hard to film and wind noise is very very annoying. |
31st Oct 2017 9:22pm |
I've subscribed to your channel as I fancy having ago at doing my own servicing next year.. I'm just weighing up options right now but will probably tackle the chassis cavity and then the underneath at a later date. I'm thinking of cleaning it out with a drain unblocking jet wash attachment, then using some fertan rust convertor in the cavity before the waxing stage.
1st Nov 2017 7:47am |
