![]() | Home > Puma (Tdci) > Very hot wheel & hub on motorway drive |
jack it up and check for play, though chances are there'll be no play, wheel off I'd check disc and pads and then remove the drive flange and look at the bearings. If the bearings are fried, you'll also almost definitely need a stub axle.
Not the end of the world. |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2192 ![]() ![]() |
Sounds like a seizee bearing to me!
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
Faulty servo can do this, however usually both wheels !👍
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 812 ![]() ![]() ![]() |
Thanks all, I guess I'm going to have to get it looked at either way - hopefully my trusted mechanic will be able to spot the problem.
If the bearing is suspect - is it worth having both ends of the axle done at the same time? (60K miles covered). |
Yes, I would be inclined too do both sides for a number of reasons. Importantly safety and peace of mind!
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2698 ![]() ![]() |
Conversely, I would say replacing both sides for the sake of it would just be wasting your money.
The life of a wheel bearing is far more than 60k (my front ones have now done 170k). They fail due to: - Lack of lubrication - Contamination - Manufacturing or material fault By all means strip and inspect the other side but if they’re in good condition there’s no need to replace them. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
I have to agree with Retroanaconda on this. Check the other side, of course, but only replace it if there is a good reason.
Coincidentally I lost one of the plastic caps off the other side rear hub a few months back, and lost a bit of grease before fitting a replacement... but it's not that side!
So yes, I'll get both sides checked - thanks! |
