Home > Puma (Tdci) > Very hot wheel & hub on motorway drive
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
After about 2.5 hours driving down the M6 from the Lakes at 70mph, I pulled into services for a break and smelt very hot/burning rubber.
On following my nose to the rear nearside, the tyre itself was only warm to the touch, but I realised that the steel wheel (wolf) was too hot to touch!
The other wheels & tyres were just warm (as expected).
After about half an hour it had cooled and I proceeded home at a slower pace, stopping about half an hour later to check the wheel, only to find it cold...
So, I'm thinking this was either a binding brake, or wheel bearing?
If binding brake, odd that filling up when home revealed an excellent 33mpg over the trip.
If bearing, why would it not have re-heated? And it isn't making any noise that I can detect.
Any ideas?
Post #660046 28th Oct 2017 1:18pm
jack it up and check for play, though chances are there'll be no play, wheel off I'd check disc and pads and then remove the drive flange and look at the bearings. If the bearings are fried, you'll also almost definitely need a stub axle.
Not the end of the world.
Post #660051 28th Oct 2017 1:54pm
bankz5152
Sounds like a seizee bearing to me!
Post #660250 29th Oct 2017 12:07pm
pannawonica
Australia
Faulty servo can do this, however usually both wheels !👍
Post #660258 29th Oct 2017 1:00pm
Ads90
Thanks all, I guess I'm going to have to get it looked at either way - hopefully my trusted mechanic will be able to spot the problem.
If the bearing is suspect - is it worth having both ends of the axle done at the same time?
(60K miles covered).
Post #660289 29th Oct 2017 3:49pm
pannawonica
Australia
Yes, I would be inclined too do both sides for a number of reasons. Importantly safety and peace of mind! Thumbs Up
Post #660432 29th Oct 2017 11:01pm
Retroanaconda
Conversely, I would say replacing both sides for the sake of it would just be wasting your money.
The life of a wheel bearing is far more than 60k (my front ones have now done 170k). They fail due to:
- Lack of lubrication
- Contamination
- Manufacturing or material fault
By all means strip and inspect the other side but if they’re in good condition there’s no need to replace them.
Post #660659 30th Oct 2017 6:54pm
I have to agree with Retroanaconda on this. Check the other side, of course, but only replace it if there is a good reason.
Post #660720 30th Oct 2017 8:55pm
Ads90
Coincidentally I lost one of the plastic caps off the other side rear hub a few months back, and lost a bit of grease before fitting a replacement... but it's not that side!
So yes, I'll get both sides checked - thanks!
Post #660748 30th Oct 2017 9:58pm
