Home > Td5 > Mirrors can stand the wind anymore
roel
Have have an anoying problem with my mirrors the co-driver mirror goes backwards at an speed off about 80 km/hr and my drivers side mirror keeps up till about 120 km/hr.
Can you adjust them to make them tighter?
Thanks Roel Roel
2003 90 Td5 (2009-now)
Post #659366 24th Oct 2017 11:35am
camelman
There is a bolt on the bottom of the mirror to adjust the tension on the ball joint.
Post #659370 24th Oct 2017 11:51am
Coatesyyy
^^ problem solved Thumbs Up
Post #659378 24th Oct 2017 11:59am
Depends if the mirror is moving with respect to the arm, or the arm and mirror are moving with respect to the door.
The former can usually be dealt with as noted above.
The latter usually requires new mirror arms.
Post #659380 24th Oct 2017 12:06pm
Avion8
Australia 2015 Defender 90 Puma 2.2 Heritage Edition SW Grasmere Green
Just had the same problem on my TD5 110, when passing road trains on fairly narrow roads with 110kph speed limit, so 220 kph passing speed, not only did the drivers mirror fall for over, but the bulkhead vent also slammed shut with a loud bang. Mirror fixed at a service station, which kindly lent me a 5/16 Allen key to do up the bolt. Also notice that my R/H rear mud flap has snapped off just below the bracket! 1955 Series 1 107" Pick up.
1977 RRC Suffix 'D'.
2000 Defender 110 TD5 Xtreme.
2015 Defender Heritage 90.
Post #659719 26th Oct 2017 8:15am
smb
On some you can do the bolt up to much and put a hairline crack in the plastic body around the bracket inside the mirror which you will only notice when it is under tension. I had this which caused the mirror body to flop down at any speed over 40mph or in high winds. When I replaced it I put a thin layer of silicon around the ball and let it dry. That way I didn't need to do it up so tight.
Post #659766 26th Oct 2017 3:24pm
roel
Problem is solved. The metal bracket that holds the mirror on the ball was more or less gone. Shocked When I put the mirror in a strange angle I had the mirror in my hand.
I had some spare mirrors so used the brackets from them and problem solved. Mr. Green
Thanks all. Roel
Post #659879 27th Oct 2017 12:27pm
