![]() | Home > Wheels & Tyres > Awww Nuts |
JustFX Member Since: 10 Nov 2016 Location: Mendip Hills Posts: 190 ![]() ![]() ![]() |
https://youtu.be/iZjk5ebcUy0
1 missing, 3 loose. I have never taken the wheels off so not my fault. But I have just been cleaning the Defender and spotted this. I heard a loud clunk the other day on the way home from work. Yesterday I noted a vague feeling from the rear and a bit of pulsing when on the brakes. These are steel nuts on alloy wheels but what are the recommended nuts for a TD5 Defender with Boosts. Should I just buy a whole new set or just try and pick up the missing one. ![]() |
I am guessing I can borrow one from the spare.
Looking on the sites they mostly want to supply the capped ones which I had on the Disco and never liked as they would occasionally go a bit wrong and not like the socket going on or be a pita to remove the socket. I will give LR a ring in the morning and get a couple of non-capped alloy wheel nuts. The measuring of the holes...do I need to go down to 0.1 of a micron or will my rapidly adjustable spanner be ok. ![]() |
NRC7415 part number single wheel nut
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 750 ![]() ![]() ![]() |
I'm not sure that 0.1 micron measurements are necessary I would have thought a half decent vernier to 0.01mm would be more than sufficient to determine if out by how much the holes may have ovalled out and any damage of note caused. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home M0XQS |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
The task of keeping your nuts shiny should be delegated to a willing member of the opposite sex
