Home > Puma (Tdci) > Prop shaft to rear diff seal leaking....
G4sweep
Germany 2012 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi,
Another bone question, here goes;
Anyone had this problem? And would anyone know if it's a DIY job or a royal pain in the backside and take it to a dealer type job? It looks fairly easy but I'm no mechanic!
Cheers Sweep
2.2 110 XS SW
Gone;
08 D3 XS
BN55 WPV G4 4.4V8 D3.
O7 G4 Mongolian Recce 110 USW
Post #65877 1st Apr 2011 1:30pm
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
I now some Pumas have had this seal fualt and was fixed under warrenty.I't is not difficult to do yourself but rather take it in if you are near a dealer. Puma 110 SW
90 V8 SOFT TOP
Post #65880 1st Apr 2011 2:07pm
Happyoldgit
You mean oil is weeping out of the nose of the rear axle just behind the propshaft flange? If so it is the rear diff pinion seal which is not difficult to replace but you need to make sure that the surface of the flange it runs on isn't pitted or grooved. As a matter of fact they changed the seal on my Puma during the first service its just had as it was weeping - as did the one on my last Puma too. Steve.
http://forums.lr4x4.com
Post #65882 1st Apr 2011 2:10pm
G4sweep
I do seem to remember that there (has/was/is) problems with the seals going. I would like to have a go myself at replacing the seal. I had a D3 before the Puma and apart from cleaning the handbrake gubbins and changing brake pads it went to a dealer for everything else, was wanting to get more hands on with the Puma rather than just rely on dealers and not know myself how to tinker around the beast.
Thumbs Up
Has anyone any experience of doing the DIY way? I'm out of LR warranty to. Sweep
2.2 110 XS SW
Gone;
08 D3 XS
Post #65884 1st Apr 2011 2:18pm
G4sweep
Yep that's the badger Miserableolgit Thumbs Up I didn't as said think it looks to much of a drama. I'm going to give it ago myself, hate paying hundred quid an hour to local dealership for something that I should be able to do myself.
Once again this forum has saved my skin! Bow down My Missus curls her top lip every time I happen to mention that I've noticed something wrong with the beast! Laughing Sweep
2.2 110 XS SW
Gone;
08 D3 XS
Post #65887 1st Apr 2011 2:24pm
MartinK
Post #65894 1st Apr 2011 2:46pm
G4sweep
Many thanks, just back from LR part dept at local dealers with new seal and 18 pounds for the pleasure lighter!
Thumbs Up Sweep
2.2 110 XS SW
Gone;
08 D3 XS
Post #65903 1st Apr 2011 3:41pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
mine has had a tiny drip on it for a couple of months but after a 800 mile round trip to Snowdon last weekend the axle casing was pretty moist. Gone back to the dealers this morning for a repair under warranty.
Does anyone know if 1 - the pinion bearing race (in the diff nose) can be replaced without pulling apart the diff - ie can you do it once the oil seal is out and; 2 could the oil seal leak be caused by worn pinion bearing and/or UJ on the prop - I have a slight vibration when I "accelerate hard" around 60mph which could be propshaft related
Post #65998 2nd Apr 2011 6:03pm
