Home > Technical > Have I damaged my ring.....
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
Stripped the hub on my 110 this evening after an issue with the top bearing.
The top bearing has been pushed down into the ABS ring and I can see where one tooth been damaged but I can’t work out whether all the teeth have been worn down on one side or whether there is a natural chamfer to them. Does anyone know?
Post #657316 14th Oct 2017 9:05pm
roel
I think your abs ring is damaged. Like mine. Twisted Evil
 Roel
2003 90 Td5 (2009-now)
Post #657323 14th Oct 2017 9:32pm
v8bobber
In fairness I think your balls and shaft have had it aswell!!
Post #657360 15th Oct 2017 8:59am
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Rolling with laughter
Post #657366 15th Oct 2017 9:13am
jst
file the bur out and see if you get an ABS fault, bet it still works. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #657442 15th Oct 2017 5:19pm
v8bobber
That’s my plan. I had a nanocom plugged in and when I was spinning the wheel it was registering a speed.
The top bearing is what’s caused the damage.....
The metal in the bearing case is pretty soft and I think the burr comes from when one of the rollers dropped out.
Post #657450 15th Oct 2017 6:16pm
jst
that looks like one of the later bearings which you now get as OEM parts, you are better off fitting the timken earlier style bearing that is not integral to the top king pin. it also has more rollers. the cgae of yours shows it with the later (less roller design) Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #657574 16th Oct 2017 12:05pm
v8bobber
I ended up buying a complete kit as the ball had some wear / grooves on it, and obviously the top bearing was mashed.
Id forgotten how much hassle rebuilding a hub is and I’ve been doing it an hour at the time in the evenings so I don’t lose patience with it.
One thing at least is that the predload is a joy to do when everything’s new. Another couple of hours and it should be done.
I hope then of course that the ABS works as it should!
Post #657754 16th Oct 2017 8:39pm
jst
we were finding those kits with the later style of bearing just werent taking the wear very well so resorted back to the older style with sep parts. its worth considering next time if you have large off sets, wide tyres or lots of 'faster' off road. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #657817 17th Oct 2017 9:19am
