Home > Technical > Rear Axle Bracket Welding
mini Anaconda
I need to replace the bracket (DA4516) on the rear axle of my 1989 Ninety which the trailing arm attaches to and have a few questions as it isn't something I've done before.
1. Do I need to drain the axle oil or will it be ok to weld as it is?
2. Where should I take the measurements from to ensure the new bracket is in the correct place?
3. Where to buy the bracket from? YRM bracket looks a good/better quality item.
4. I would be paying someone to do it (no welding facilities), how much would I be looking to pay?
Any other advice & tips would be gratefully received.
Thanks in advance Bow down BORG - Bucks & Oxon 4x4 Response Group
Post #657282 14th Oct 2017 7:56pm
sgilmour
United Kingdom 1994 Defender 90 300 Tdi CSW Arles Blue
I had this exact job done on my 90 earlier this year. Can recommend the YRM bracket, got one on mine and was able to weld (apparently not always possible depending on the state of the axle and if the weld will take or not).
Can't answer the oil or measurements questions but I had Essex 4x4 do mine and it was just over £100 IIRC.
Good luck!
SG 1994 Defender 90 300TDi
2002 Disco II ES Td5 Auto (SOLD)
2011 BMW 120d M Sport
2012 Audi A5 Coupe 2.0 TDI (Other halfs)
Post #657288 14th Oct 2017 8:13pm
I did my own.
No need to drain it
If you grind away the bracket with care you can mark straight lines with a marker or hole punch guide points
YRM
The axle was off, which made it easier. I put strengthening plates over both sides too, for extra peace of mind.
I initially forgot to scoop out the strengthening pieces, so there was no travel for the rear arms Laughing the joys of self build!!!
Post #657292 14th Oct 2017 8:22pm
mini Anaconda
Thanks SG/Greeni, I'll keep it in mind.
The rest of the axle looks good so hoping welding will be okay, it is just the bracket. I'll crawl under for a picture tomorrow, it looks more like a crack that something that has just rusted through from a quick look today. BORG - Bucks & Oxon 4x4 Response Group
Post #657297 14th Oct 2017 8:48pm
jst
Britpart also sell the bracket and its up to spec for the job.
mark the centre line position of the current plates welded on with centre punch into axle, cut off the old ones, mark again, clean it up remarking the centre punch holes as required depending on how much is needed to be ground down. line up new one with centre punch marks
you dont need to drain the oil out. if still concerned you could jack up the side your working on (then use axle stand to support) Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #657304 14th Oct 2017 9:06pm
mini Anaconda
Here's the best photo I could manage in smart clothes at work...
Post #657739 16th Oct 2017 9:11pm
Coatesyyy
Condition looks good to weld Thumbs Up
Post #657753 16th Oct 2017 9:38pm
mini Anaconda
That's good news. Very Happy
The rest of the chassis is sound, just seems to be this bracket. Rolling Eyes BORG - Bucks & Oxon 4x4 Response Group
Post #657755 16th Oct 2017 9:40pm
jst
hard to tell from pic, but that looks ok to weld, casing looks fine. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #657819 17th Oct 2017 10:30am
