Home > Technical > Windscreen wiper defects
Solomog
England 2009 Defender 90 Puma 2.4 SW Galway Green
Both Windscreen wiper intermittent and wash auto park stopped working. Wipers work in normal mode and washer works fine. Visual cHecked fuses seem okay.
Post #655595 7th Oct 2017 10:44am
ibexman
Probably column stalk contacts
Post #655608 7th Oct 2017 11:34am
mk1collector
Park switch on the motor, common problem. Ray
My build thread
Post #655613 7th Oct 2017 12:30pm
Martin
Site Admin
Not clear what the fault is, whether it's not parking all the time, not stopping during intermittent, not stopping after a wash, and so on.
Can you clarify?
A fuse issue would be all or nothing - the wipers wouldn't work at all.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #655614 7th Oct 2017 12:33pm
Solomog
Thanks for the replies. As requested I'll try to be more specific. Intermittent does not function at all. On wash the water squirts and the wiper makes it's 3 or 4 auto wipes but then stops wherever it likes rather than in the park position. If it's the wiper park switch, what is the fix, replace the wiper motor? I've made an attempt to get to the stalk switches, decided that the steering wheel needs to be removed to be able to remove the plastic covers, the steering wheel is well stuck, left it soaking in some penetrating fluid, suspect I'm going to need some kind of puller to get the wheel off. Is there a common relay that might work the intermittent/ wash park?
Post #655680 7th Oct 2017 7:07pm
Martin
Site Admin
Does it wipe and park ok in the normal constant wipe modes (slow and fast)?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #655990 9th Oct 2017 6:00am
Solomog
Put the wipers through a full operational check. In normal operation wipers work and park as advertised, functioning correctly. No operation whatsoever in intermittent. Push the wash and get a jet of water, no auto wipe. Thanks for your help.
Post #656077 9th Oct 2017 2:21pm
Martin
Site Admin
As they will park themselves in normal operation then the park switch itself would seem to be operating OK.
It sounds to be related to the intermittent wiper control unit, either it is loose, faulty or there is a poor connection to it.
Try reseating it and/or replacing it temporarily with another unit from another Defender (if you have access to one).
It's the large red "relay" at the top middle behind the panel under the steering wheel. Part number AMR2341 on it.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #656098 9th Oct 2017 3:45pm
Martin
Site Admin
2015 D90 XS SW
Post #656099 9th Oct 2017 3:49pm
Solomog
Removed the relay and refitted, wipers now work perfectly. What can I say .... thank you so much for you advice and expertise, top man.
Post #656296 10th Oct 2017 11:13am
Martin
Site Admin
Cheap fix Thumbs Up Laughing  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #656297 10th Oct 2017 11:14am
