Home > Technical > Air intake pipe replacement and sealing on 2.4 TDCI |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2429 |
Hi all
I have a full external cage on my 110 so Im not sure if the nugget stuff air intake kit will fit so Im going to put it out there to you guys about what solutions you have come up with, I would prefer to use this hole rather than any others i.e. wing top or new holes. Click image to enlarge Click image to enlarge cheers Ken 2008 Santorini Black 110 XS USW (Sold) 2015 Discovery 4.5 Black pack Firenze red XS 2008 Corris Grey 110 XS USW (sold) 2011 Santorini Black 110 XS USW (Sold) |
30th Sep 2017 7:32am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
1st Oct 2017 4:09pm |
cheers Leeds but unfortunately out of my price range for bits of flange and pipe, Im going to get some made up now as I dont like the other options so far. 2008 Santorini Black 110 XS USW (Sold)
1st Oct 2017 6:20pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17527 |
The Nugget duct won't fit there.
The Erhöhte Luftansaugung gets my vote:- Click image to enlarge |
1st Oct 2017 9:52pm |
one of these and design the pipe work to your spec Click image to enlarge |
2nd Oct 2017 6:56am |
tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129 |
My defender has 6 point ezternal roll cage too
I have also installed a snorkel but I used the metal mantac snorkel (old style and just bolted a flange on the snorkel kit and run a 3 inch silicone pipe all the way to the airbox, then followed by a 3inch to 4 inch silicone adapter. As the airbox end is 4 inch Finanly I used some water pipe clamps to secured the snorkel pipe |
3rd Oct 2017 9:23pm |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 |
I have the Nugget intake fitted and a Safety Devices 8 point internal/external cage fitted.
The wing intake end fits OK, but has to be re-drilled if you wish to re-fit the original intake grille (as I did at the time) but I don't particularly like the adapter fitting that goes into the airbox, as it is almost an interference fit against one of the engine-mounted bolts. It hasn't rubbed through yet but I suspect it's only a matter of time. I've also seen that they are now supplied with a pipe that looks pretty shonky in comparison to the old type I have. It looks like your cage intrudes more into that space so I couldn't be definite about whether it will fit or not. I'm going to see if I have some pictures and will post them if I can find them. |
7th Oct 2017 9:03pm |
Click image to enlarge This shows the view from behind the wing, and it only just clears the SD bracket that bolts to the bulkhead. It is however quite a shallow box so might sneak in behind the tube that you show. |
7th Oct 2017 9:15pm |
