Home > Puma (Tdci) > My gear change
TOP5N
My gear change
I have had my defender a week now, and I am still struggling to get a consistent gear change. 50% of the time I get it perfect, and the other 50% of the time it feels like the clutch has a totally different biting point, which makes the drive gear clunk... there is no noise from the clutch or anything on tick over, and it seems to select gears fine, so I'm a bit confused as to what is going on....
2015 XS 90 with 22000 miles
Chris
Post #654199 1st Oct 2017 8:22pm
Failed or failing clutch switch. WeWillWin🇬🇧🇺🇸
Post #654201 1st Oct 2017 8:23pm
TOP5N
Thanks for the reply Steve.. that is almost how it feels to be honest, I�m guessing the clutch switch adjusts the engine revs accordingly or something similar..
Post #654215 1st Oct 2017 8:45pm
Yes, I believe it creates a slight rev hang on gear change.
It also increases revs on low range which is incredibly annoying.
You can go completely without it with no ill effects at all, but it must be bridged and not just unplugged on a TDCI.. WeWillWin🇬🇧🇺🇸
Post #654229 1st Oct 2017 9:10pm
Puma_MOG
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
TOP5N,
I seem to be in the same boat, most times it's quite fuss free, other times I get a clunk but figured I was being too abrupt with my shifting. Is your cluck coming from a particular area? From what I can tell it almost feels like something is loose outback.
Would be interesting to know how you get on.
Cheers,
P
Post #654905 4th Oct 2017 5:52pm
A frame ball joint is possible too. WeWillWin🇬🇧🇺🇸
Post #654913 4th Oct 2017 6:32pm
newhue
Australia
I asked my dealer to deactivate that very odd clutch rev combo, and they did but I have no idea how. I also had the slop that comes standard in the rear diff tightened up. Dealer didn't do that as they said it was normal.....so no more drive line bangs, no more terrible gear changes. My Defender and travels
Post #655468 6th Oct 2017 7:49pm
TOP5N
How did you tighten up the slop in the rear diff..
Post #655469 6th Oct 2017 8:00pm
newhue
Australia
Took it to a specialised diff repair shop. My Defender and travels
Post #655470 6th Oct 2017 8:02pm
Puma_MOG
Thanks for the follow up and feedback. I'll need to check this out as it sounds mine is exactly how yours was.
Enjoy the smoothness now Smile
Post #655476 6th Oct 2017 8:13pm
TOP5N
I am still getting drive train bangs about 50% of the time. I can let the clutch out really slow and just suddenly "bang" as it bites, and that is literally being extremely slow on the clutch... Disabling the clutch / rev hold switch didn't really make any difference... my defender has only done 23000 miles and two and a half years old... thinking of going back to land rover with it.
Chris
Post #658750 21st Oct 2017 3:41pm
