Home > Puma (Tdci) > Clutch change, Ashcroft adaptor shaft, questions and cockups |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17537 |
24th Sep 2017 10:48pm |
Olsey Member Since: 17 Mar 2015 Location: Doha, Qatar Posts: 27 |
Hi Ben,
Have you got around fixing up your issue? If so, how'd you go? I'm about to drop the gearbox/tcase on mine. Did you follow the workshop manual? If so, are you reusing parts that the manual states you need to renew? Cheers, Tim |
28th Sep 2017 2:10am |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 429 |
Hiya Tim,
Yes I've spoken to Ashcroft who have sorted a replacement part. Luckily not at a horrendous price as I was expecting! Workshop manual was handy, as well as a PDF from a Land Rover Magazine about the fitting procedure for the Ashcroft kit. Really though, it's all pretty self explanatory. Driveshafts, handbrake drum, exhaust, cubby box. I am however going to replace the bolts that I should be renewing. Are you doing the clutch upgrade too? Because Clutchfix have given me all the latest slave kit in the box. Just need belhousing bolts, adaptor shaft bolt and some seals I think. Cheers |
28th Sep 2017 2:18am |
Hey Ben,
Nah, not doing the clutch but will inspect it anyway. Dropping it to fit a new breather port that's part of a raised 5-port breather manifold. Can't get to it in situ to work on. I will also inspect the output shaft. Don't have the money to install a Ashcroft Output Shaft Kit at the moment. But that might change when I look at the output shaft. The workshop manual states to install a new o-ring seal for the clutch slave cylinder fluid pipe, but apparently the o-ring is not available on it's own. You have the purchase slave cylinder adapter or whatever, the fluid pipe connects to. I think some people just reuse the o-ring instead of purchasing whole new slave cylinder parts. Cheers, Tim |
28th Sep 2017 2:46am |
Ah ok! I'd really recommend looking at both. They seem like a real issue from the factory.
If you cannot afford the Ashcroft upgrade I wouldn't worry too much. I'd say a new shaft from LR with a load of grease should last a bloody long time. More than enough time to wait until you need to do the clutch (if you get away with it this time). Like I said, with my HD clutch I've received all the new slave stuff, so I'm hoping theres an O ring in there too! Just out of interest, as I'll be keen on doing the breather too, is it a 1/8" BSP fitting that needs to go into the gearbox housing? I was looking at getting a right angled, swivel, stainless 6mm push fit connector and a bit of 6mm hose for that job. |
28th Sep 2017 5:08am |
If you're going to the trouble of removing the transfer box I would strongly recommend inspecting the clutch driven plate and the output adaptor shaft even if you don't initially plan to replace either. Both are notorious weak points in the Puma driveline, and inspecting them adds little time to the job. You will kick yourself if you don't and either fails just after you've got it all back together.
Clutch driven plates, even the latest version, can suffer from spring failure in as little as 20k miles, and it is almost certain that the springs will have taken a permanent set by 50k, even if the clutch isn't rattling and the vehicle still drives. The adaptor shaft should be lubricated at any opportunity if you want to preserve it. It is still a mystery why some adaptor shafts last indefinitely while others fail under 10k miles. There must be more to this than just lubrication. |
28th Sep 2017 9:22am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2314 |
Nice combo Just had an ashcroft kit and clutchfix kit put in mine.
28th Sep 2017 12:46pm |
Good stuff hank! You finding much difference between the clutches? Any reduced driveline knock reduction with the new shaft?
Tim I think the part you need for the slave is LR068981. That's what came in my clutch kit. |
28th Sep 2017 1:18pm |
Nothing noticeable on driveline knock to be honest, however my drive flanges are sloppy and need replacing so difficult to tell.
No noticeable difference on clutch feel but it works as it should and no problems towing so I'm a happy customer I had them done as the box was coming off anyway to replace leaky crank main oil seal. Defender is on 75k and no history of clutch or shaft being done so thought it was probably worthwhile refreshing both. |
28th Sep 2017 2:24pm |
Hi Ben,
I'm not exactly sure what size fitting it is, but I've just received Gwyn Lewis' diff/axel breathers which are M12 thread (you do have to tap the thread though. The breather manifold I've purchased is Nugget Stuff's 5-port breather. The photo of the manifold kit shows a brass fitting. That is what fits into the gearbox breather port and the push-in fitting takes 6mm nylon tubing. I wouldn't be surprised if its a 3/8 BSP, though I'll try and find out exactly. Cheers, Tim |
29th Sep 2017 1:17am |
I think the Glyn Lewis kit uses an M12 fine series thread, not the more common coarse series found on 'normal' M12 nuts and bolts. Worth cheicking that the tap you're going to use matches the fitting before tapping the hole.
I may be wrong however since I haven't seen the kit in the flesh. |
29th Sep 2017 7:46am |
Yep, I made sure I ordered the tap as well, which Gwyn stocks.
29th Sep 2017 9:41am |
tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129 |
Thanks for sharing this.
I went underneath her and found red dust too in the gearbox transfer box joint. I am thinking of doing this But just wondering how hard it is. I have replaced the rotor and not afraid to give it a try Is there any special tools that I need? Thanks |
30th Sep 2017 3:54am |
It's all pretty straight forward. The only things that are a little harder and might be worth buying specialist tools for are a transmission jack, clutch alignment tool, and something to hold the drive cup as mentioned above.
Other than that, all should be doable with some torx bits, a decent socket set (with a breaker bar) spanners. Although bear in mind that I've not actually got my gearbox back in yet. That could be the difficult bit! Any other questions give me a shout and I'll do my best to help. |
30th Sep 2017 11:39am |
