Home > Technical > Exhuast gasket after turbo |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2162 |
On a TD5 there is. Dont know about others
27th Sep 2017 3:41pm |
There definitely will be a gasket between the turbo and down pipe. Thing to listen out for is the flexi joint just below the union can also wear and spring a leak. It should be noticeable by black soot around the area it is escaping from.
27th Sep 2017 3:51pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8022 |
thank you, does anyone have a part number, mine doesnt have one fitted! Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
27th Sep 2017 5:24pm |
I think it is the same as the TD5... something like esr3737
27th Sep 2017 5:38pm |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 429 |
I've just had my exhaust off my 2010 and not found a gasket. Didn't leak though. Might be worth cleaning up the mating surfaces and torquing it back up.
27th Sep 2017 7:12pm |
well i dont think there is one there from digging i have done but i seem to remember an aftermarket gasket being thicker which i think was to go here but not sure. Cheers
27th Sep 2017 8:13pm |
its a 4 hole bolt design Cheers
27th Sep 2017 8:15pm |
http://www.ebay.co.uk/itm/EXHAUST-PIPE-FRO...SwWTRWuKFe
^^ maybe? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
27th Sep 2017 8:17pm |
http://www.defender2.net/forum/post360508.html
this is the post i was refering to, so this relates to another gasket i take it as ref to a 3 hole Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
27th Sep 2017 8:20pm |
I am getting a bit of squealing from engine area which i assumed was the mating of the down pipe to the 4 bolt exhaust/turbo manifold. thoughts please? Its under load. Cheers
27th Sep 2017 8:26pm |
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 724 |
Hi james what truck is it on, sounds like the td5 exhaust manifold warped, similar to when you whistle a blade of grass between your fingers?!?..
Check for soot around manifold/studs.. Cheers Alex 98 300 tdi 90 project 94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility |
27th Sep 2017 9:31pm |
28th Sep 2017 5:10am |
its a brand new downpipe. the old one didnt have a gasket in there, there isint one there currently, its whistling and i wondered if there is meant to be a gasket in there and what MPN it is if there is one
2007 tdci 2.4 Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
28th Sep 2017 6:14am |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 |
When I put my 2011 110 2.4 puma on the hoist I thought I'd lost the gasket on fitting the decat pipe on to the turbo. So rang the dealer parts department in panic, and was told there was not one.
28th Sep 2017 9:43am |
