Home > Puma (Tdci) > Turning circle -
GN
Turning circle -
Does anyone know of any way of improving the turning circle on a 110 (running std Boost alloys with 235/85 16s) ?
Have heard that adding wheel spacers can help a bit - are there any other ways?
Post #65240 27th Mar 2011 2:16pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Stick it on a trailer, improves the turning circle no-end Rolling with laughter
Post #65250 27th Mar 2011 3:48pm
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Wheel spacers have worked for me Smile once you have them you can adjust the steering bolts to get a better turning circle.
Jack
Post #65254 27th Mar 2011 4:49pm
G4sweep
Germany 2012 Defender 110 Puma 2.2 XS CSW Santorini Black
There is a bolt on each side near the swivel joint/housing?, don't know the technical name; steering stop. If you adjust these with your front wheels off the ground on axle stands, you can sort out your turning circle of a jumbo jet! I'm sure someone will be along with a detailed way soon to explain in better English and more technically than ive put it. I have just sorted mine this way, just remember to do the same to both sides and don't over do it like I did first time round or you will end up with the tyres rubbing or even worse knackering the swivel housing! Embarassed you should try a search on here as there are some photos of said bolts you need to adjust.
Thumbs Up Sweep
2.2 110 XS SW
Gone;
08 D3 XS
BN55 WPV G4 4.4V8 D3.
O7 G4 Mongolian Recce 110 USW
Post #65256 27th Mar 2011 4:58pm
Alive Tuning
As above, just wind the stops in enough so you still have clearance between the tyres and radius arms. Thumbs Up
Post #65422 28th Mar 2011 7:52pm
BigMike
You dont need to put it on axle stands. just get someone in the driving seat with the engine running to go lock to lock. just remember that on full lock one way you adjust the other side as you have access, then turn it back to see the clearance on the radius arms. LR says you need 20mm but I put mine about 8mm
Post #65430 28th Mar 2011 8:29pm
AJS4X4
30mm spacers and you will have all the lock you need once you adjust the lock stops. Thumbs Up
Done this to mine and fitted 265/75x16, works well for me.
Andy.
Post #65432 28th Mar 2011 8:32pm
noworries4x4
Just one word of caution with winding the stops out to far with wheel spacers watch the oil seals on the chrome balls dont get damaged as they will if you go to far If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #65437 28th Mar 2011 8:38pm
AJS4X4
Thumbs Up
Post #65439 28th Mar 2011 8:44pm
AndrewS
And don't over adjust as you may over stress the CV joints. Does anyone know what the maximum angle is that they can handle? 130's have feeling's as well you know Smile
Post #65442 28th Mar 2011 8:57pm
