Home > In Car Electronics > Tow electrics ignition trigger
mse
Finally got round to finishing wiring in the 13 pin electrics.
Is there an ignition trigger in the driver seat fuse box instead of running up to the dash, which means loads of carpet and soundproofing removal!
Thanks Mike
Post #652475 24th Sep 2017 9:04pm
Martin
Site Admin
Yes absolutely on a 2.2
I've done just this to save faffing with the dash. I'll dig the colours out for you later.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #652479 24th Sep 2017 9:10pm
Martin - Is there just for the 2.2? What about the 2.4?
I thought the 2.4 didn't if I remember rightly. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #652489 24th Sep 2017 9:21pm
Martin
Site Admin
No ignition sources in the under-seat fuse box on 2.4 as far as I know. The 2.2 does have some.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #652490 24th Sep 2017 9:23pm
mse
Thanks Martin, brilliant if you could, I looked at wiring it to the dash, just moving the carpet stopped me! Mike
Post #652521 24th Sep 2017 10:48pm
Martin
Site Admin
These are the ignition sources in the seat box fuse box on a 2.2 Puma:
Mine's on the speedo transducer line (Fuse 11).
I suppose you could use a fuse-tap too Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #652581 25th Sep 2017 9:59am
mse
Great, thanks i will have a look when (if) it stops raining Thumbs Up Mike
Post #652583 25th Sep 2017 10:00am
Martin
Site Admin
Hahahahahahaha  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #652584 25th Sep 2017 10:01am
NormanD
England 2015 Defender 110 Puma 2.2 USW Santorini Black
Are there any first position on the Ignition switch feeds from the under seat fuse box, I would like to find one if possible. NormanD WE191
2015 110 XS Utility
2014 VW Caravelle 180 Executive
Post #652638 25th Sep 2017 1:43pm
Martin
Site Admin
No, only in the dash fuse box.
Fuse 26 - lighter socket
Fuse 27 - Radio
Fuse 28 - heater fan  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #652669 25th Sep 2017 3:44pm
