![]() | Home > In Car Electronics > Tow electrics ignition trigger |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6662 ![]() ![]() ![]() |
Yes absolutely on a 2.2
I've done just this to save faffing with the dash. I'll dig the colours out for you later. ![]() ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20761 ![]() ![]() |
Martin - Is there just for the 2.2? What about the 2.4?
I thought the 2.4 didn't if I remember rightly. WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
No ignition sources in the under-seat fuse box on 2.4 as far as I know. The 2.2 does have some.
mse Member Since: 06 Apr 2008 Location: UK Posts: 5090 ![]() ![]() ![]() |
Thanks Martin, brilliant if you could, I looked at wiring it to the dash, just moving the carpet stopped me! Mike
These are the ignition sources in the seat box fuse box on a 2.2 Puma:
![]() Click image to enlarge Mine's on the speedo transducer line (Fuse 11). I suppose you could use a fuse-tap too ![]() ![]() ![]() |
Great, thanks i will have a look when (if) it stops raining
Hahahahahahaha
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 287 ![]() ![]() ![]() |
Are there any first position on the Ignition switch feeds from the under seat fuse box, I would like to find one if possible. NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
No, only in the dash fuse box.
Fuse 26 - lighter socket Fuse 27 - Radio Fuse 28 - heater fan ![]() ![]() |
