![]() | Home > Technical > A couple of noises... |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5879 ![]() ![]() ![]() |
Just a quick email on behalf of a friend who owns a MY2011 2.4SW.
He has noticed two noises recently that he can't pin down. He took me for a spin and we think we've identified the location, just Not what the noises are. Both sound mechanical as opposed to trim etc. First is a light grating/grinding from the area of the rear axle. More pronounced at speed and when the suspension goes through some flex. Not a hard bump but if for example it is driving on a dual carriageway that rises and falls, so each time it goes through a hollow. As I said, not a loud painful grinding, very low key, almost anonymous and you wouldn't hear it I felt the window was open or the music is on. But definitely there and definitely constant. I did notice this in another Def I drove a couple of weeks ago, so is it just one of those things? If not I'm wondering if it's bearings, lack of oil in the dif or perhaps dirt in the shocks? The second noise comes from under the gear box area, seemingly the LHS. It's not nearly as common as the first noise apparently, and it took quite a few runs before we heard it. Simply, if he's been driving fast, (sixth gear, dual carriageway or similar), for a relatively long period of time (some minutes or more), and arrives at a roundabout or toll, when he lifts off the accelerator to start coasting, there is a sharp, high revolution spinning sound from under the cabin. I can only liken it to the sound of a circular saw slowing down. Hi rev, metallic, sharp, spinning. Any thoughts on either would be much appreciated. ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3658 ![]() ![]() ![]() |
after the tyres check all the oil levels and grease the shafts DEFENDER 90 TDCI XS,
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
The second noise sound like the turbo boost pressure hose possibly has a slight leak or it is just the turbo pressure adjusting. We have the similar noise on my wife's Evoque. Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
Hi Jeff, thanks for the thoughts. Is the sound on your wife's Evoque a hissing sound given it was a split pipe or metallic/mechanical. If the latter, were you hearing the turbo through the split? The one I heard is very definitely mechanical/metallic and seems to come from under the Chassis, in line with the gearbox, and if I had to guess, left hand side of the prop shaft. Can be heard faintly through the floor, clearly if the window is open. I would liken it to a bench saw having just been used in a joiners, the blade spinning but slowing down. If I recorded it and heard it blindfolded in a studio, that would be my first and only guess...
Thank you and thanks Landyman. My mate is due to do full oil change and aims to do grease on bearings, so we'll find out what levels they're at, but I shall also recommend he checks the tyres. However I'm pretty sure they're BFGs, 18" on Sawtooths that are under a year, and well under 10,000 old. Will let you know what we find out. Ta. ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
The sound on the Evoque is more like a wheel spin /skid but occurs after slowing down for a bend or roundabout and then accelerating slowly rather than booting it to cause the spin. There is a whole thread on the BabyRR forum but no one has an answer, even the dealers just suggest that it what they do!! Sound comes from the passenger side/left front. Jeff
LANDROVER Member Since: 13 Feb 2016 Location: EAST OF ENGLAND Posts: 216 ![]() ![]() |
I remember the same used to occur with the Goodyear tyres on the Range Rover L322. They came with the wranglers on the 18" wheels and they used to wear unevenly. I think it was referred to as cupping..basically uneven tread wear of the blocks creating the same noise you mention. |
