![]() | Home > Td5 > a low-frequency whooop-whooop noise final drive (rear diff ) |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1230 ![]() ![]() |
This might be 1000 miles off but the sound you described happened to me with our Freelander 2 not so long ago. Everyone pointed me to a rear diff pinion bearing but it turned out to be a rear wheel bearing. Drove us mad with the sound, bearing fitted-stopped immediately!
thank but both rear wheel bearing have been replaced
![]() having removed final drive and checked it over ![]() |
What tyres do you have?
7.50 16 Mitchell XZL MS but had same noise with diffract make tyre same size
Not the rear diff
![]() the hunt is still on, will not be beaten next ![]() |
i have cunning plan 3 mic and laptop and soft ware i will place the mic and go drive will update
tyre and wheel swiped from front to back diagonally and You here YOUR SELF think
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2118 ![]() ![]() ![]() |
I have just had mine in the main dealers to double check for the same - it was the tyres that had uneven wear on the tread ... swapped front to back and it improved ..
I have wrangler M/T's on mine at the moment Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
7.50 16 Mitchell XZL MS on the pick up 90 with problem
and BFG 235 85 16 AT ( *^) on the HT 90 and no problems at tall fitted 03 and still going strong TYRES and tracking drive like new ![]() |
