Home > Td5 > a low-frequency whooop-whooop noise final drive (rear diff )
dorsetsmith
TD5 06 pickup 47,000
A low-frequency whooop-whooop noise in all gears oil leave ok in both boxes, UJ replaced X4, output bearing replaced in Transfer box, wheel bearing checked all ok
looking for way check the final drive Question
drive off
Post #635055 2nd Jul 2017 10:01am
seriesonenut
This might be 1000 miles off but the sound you described happened to me with our Freelander 2 not so long ago. Everyone pointed me to a rear diff pinion bearing but it turned out to be a rear wheel bearing. Drove us mad with the sound, bearing fitted-stopped immediately!
Post #635144 2nd Jul 2017 7:20pm
dorsetsmith
thank but both rear wheel bearing have been replaced Crying or Very sad
having removed final drive and checked it over Exclamation
Post #635235 3rd Jul 2017 5:56am
Laurie
What tyres do you have?
Post #635252 3rd Jul 2017 8:59am
dorsetsmith
7.50 16 Mitchell XZL MS but had same noise with diffract make tyre same size
Post #635257 3rd Jul 2017 9:29am
dorsetsmith
Not the rear diff Thumbs Up
the hunt is still on, will not be beaten next Exclamation
Post #636241 7th Jul 2017 4:01pm
dorsetsmith
i have cunning plan 3 mic and laptop and soft ware i will place the mic and go drive will update
Post #636979 11th Jul 2017 7:07pm
dorsetsmith
tyre and wheel swiped from front to back diagonally and You here YOUR SELF think Exclamation not 100% but big in-promovent ( sawtooth tyre wear ) Idea
Post #652262 23rd Sep 2017 11:04am
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
I have just had mine in the main dealers to double check for the same - it was the tyres that had uneven wear on the tread ... swapped front to back and it improved ..
I have wrangler M/T's on mine at the moment Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #652270 23rd Sep 2017 12:20pm
dorsetsmith
7.50 16 Mitchell XZL MS on the pick up 90 with problem
and BFG 235 85 16 AT ( *^) on the HT 90 and no problems at tall fitted 03 and still going strong
TYRES and tracking drive like new Thumbs Up
Post #652273 23rd Sep 2017 1:10pm
