![]() | Home > Puma (Tdci) > Is yours that rusty ? |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 ![]() ![]() ![]() |
![]() Click image to enlarge is this normal ? Should I point this when I take it to the dealer next month for 1year/20000km service? Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
It was starting but sprayed it with ACF 50 which seems to have stopped it .
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
That +the Turbo casing will both show a cover of rust because of the temp: burning off the paint and the material they are made of - I believe Cast Iron or similar. It's normal and nothing to worry about. You could paint with engine paint or something similar but it will be an ongoing job.
