Home > Puma (Tdci) > Allisport Puma coolant tank
Baytown
Australia 2012 Defender 110 V8 Petrol CSW Auto Blenheim Silver
Hi folks.
I've just fitted the great quality Allisport coolant expansion tank to my 2012 110, replacing the plastic OEM unit.
I'm not happy with the interference to the Metal line against the fire wall.
Am I missing something here re fitment of this unit?
The mounting plateis attached to the upper lip as per the original expansion bottle, the bolt is secured as OEM, but one of the lines has to run under the mounting plate which concerns me.
Has anyone else had issues re this?
Thanks.
Ken
Post #592013 11th Jan 2017 6:03am
jst
metal line? you mean one of the brake lines or clutch line i guess?
just pad it out with some foam (old roll matt) and cable tie it in place. neither move under normal application the padding will stop rubbing under vibration especially if you cable tie the tow together so they cant move independently.
or bend it away. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #592295 11th Jan 2017 9:31pm
Baytown
Hi James, yes, I think it is an ABS line.
I was going to place rubber over it, just wanted reassurance about having themounting plate over the top. Anything to stop vibration of this item on Australian correlated bush roads.
Thanks and best wishes.
Ken
Post #592337 12th Jan 2017 1:19am
pannawonica
Australia
The tank you have fitted looks like a great bit of kit, it is something I have been thinking about myself!😀👍 However just shelled out for one for my MGR V8 I view of the fact being older! The advice I had received was ageing plastic expansion tanks at pressure don't leak but let go! From appearance condition cannot be determined! Thumbs Up
Post #592339 12th Jan 2017 1:39am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Now with Sight Glass and level sender
Defender Puma TD4 2.4 Tdci Header Tank with sight glass + level sender
https://www.allisport.com/shop/performance...ght-gauge/
Or :
Defender Puma TD4 2.4 TDCi Header Tank with Sight Glass
https://www.allisport.com/shop/performance...ght-glass/ Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #652060 22nd Sep 2017 11:30am
HardCharger
Out of curiosity, how does one make the level sender work? I don't think there are lights on the panel that correspond to this?
I was actually just planning to upgrade to the header tank with sight glass as I can't see through the plastic one anymore. Now the addition of the level sender makes me curious. Though I think I'd like to keep things as simple as possible.
Also, looking at the photo above, why does the cap have a hose and what does it do? Is it part of the level sender system?
Post #652198 23rd Sep 2017 3:55am
Theater
MADMAN EMS2
or a gauge , VDO for example .
The cap is IVECO
dgardel wrote:
Regard wrote:
Sure it is not the cap?
These things start to leak every few thousand miles. Here in SA we have a "rule of thumb" that you should replace your cap every 10k km (+_ every 7000 miles). They are cheap (£7 odd per cap from dealers) so worth changing regularly!
Allisport makes a nice allu tank that replaces the standard one. The only issue I have with those is......how the heck do you see the coolant level?
better and definitive solution
P/N is IVECO 99489567
http://www.defender2.net/forum/topic22672.html?highlight=dgardel
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Marco
Post #652208 23rd Sep 2017 6:10am
zsd-puma
I assume that Iveco cap opens at the same pressure?
Post #652265 23rd Sep 2017 11:34am
Theater
Yes .
http://www.africaland.it/forum/viewtopic.php?t=94121 Marco
Post #652324 23rd Sep 2017 6:38pm
HardCharger
So the Iveco cap allows the pressure to bleed off via the hose and not kill the cap? And I presume any "excess" coolant will bleed through the hose? How do we keep things from going up the hose in the event of the a deep wading scenario?
I've had to replace my cap once thus far, and yes, currently in a tropical country if it makes a difference. I have noticed that my second cap is starting to let coolant dribble down the coolant tank so it may be time for a new one and may go the Iveco route.
I tried reading through the thread Theater posted and google translate makes for some strange and entertaining reading but I think I may have gotten the gist of things but better if I can ask for specifics on a more English oriented site.
Post #652541 25th Sep 2017 3:15am
Theater
Hi HardCharger ,
on the link the thread " Coolant expansion tank cap (IVECO vs. OEM) " of dgardel on Defender2.net forum :
http://www.defender2.net/forum/topic44373....o+99489567 Marco
Post #652552 25th Sep 2017 5:39am
zsd-puma
well it would have nowhere to go. The cap has a pressure valve in it, if the valve opens the pressure in the cooling system will be more than enough to clear the hose and stop anything going up it. Not to mention when the valve is closed (which is most of the time) the air lock in the hose would stop anything significant going up it.
Post #652642 25th Sep 2017 12:55pm
dgardel
Italy
The difference is that the IVECO cap work well where the original LR loose coolant.
Since the day I started using the IVECO cap, the coolant level has never dropped. Previously, with the original LR cap, after every refill, the level dropped below 3 to 4 cm from the "equator" of the bowl after 200-300 km.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #652695 25th Sep 2017 4:17pm
HardCharger
Theater wrote:
Hi HardCharger ,
Thanks, Theater. I missed that post for some reason.
Post #652819 26th Sep 2017 2:48am
HardCharger
Thanks for clearing that up, zsd-puma! I guess you have to disconnect the hose when topping up though, small detail.
Post #652820 26th Sep 2017 2:49am
