![]() | Home > My Defender > My new 200tdi hardtop 'project' |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2711 ![]() ![]() |
You're into personal opinion territory really, however my thoughts are that if you've got a 'posh' one to use when you're feeling so inclined then I wouldn't bother.
A Land Rover that is used properly for carrying, towing, travelling etc. will get dents and bumps and so long as panels aren't destroyed or big holes appear they don't detract from the appearance. |
Coatesyyy Member Since: 07 Sep 2017 Location: Knutsford Posts: 423 ![]() ![]() |
I reckon it looks cool mate, like a proper work hard 90 should!
okennedy Member Since: 12 Sep 2017 Location: Roscommon Posts: 42 ![]() ![]() |
If keeping it original, then the small dings/dents are what makes it an 'honest' vehicle IMHO. But as stated it's up to you...
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5244 ![]() ![]() |
no harm in giving it a little tidy up even though its a works one, They all do need loving, Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 527 ![]() ![]() |
It does look lovely now.. It's one of those dilemmas, you know once you start on one thing it will lead to another and another..........
I'm a bit precious about Alan but it doesn't stop me putting sacks of stinky manure, filthy wet dogs in the back, lengths of scaffolding boards on the roof or going for the logs with the trailer.. So I say go for it.. ![]() |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1876 ![]() ![]() |
Alan was actually one of the inspirations as he is Arles/Windjammer 👍🏻 Rob
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
Bit of an update after my beloved has been away for about a month with a great local LR specialist who is also a really good friend:
Head gasket started chuffing at the rear so head skimmed and gasket replaced. New head bolts, rocker gasket & valve stem seals. Cam belt, tensioners and seals replaced as no idea when last done Replaced alternator and water pump belts New rear prop & water pump Full service including all new glow plugs Replaced front wheel bearings and seal Mantec swingaway fitted Replace front bumper with HD version from Dixon Lovely to have a him home again and drives all the better for it ![]() 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
under_rover Member Since: 02 Apr 2013 Location: Yorkshire Posts: 152 ![]() ![]() |
There's always something to tinker with
![]() Laurie 90 rebuild thread - https://www.defender2.net/forum/topic62909.html |
