![]() | Home > Technical > transfer box oil spec and capacity |
if you drain the transfer box and then remover cover plate more oil will drain out
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Exactly, i don't see the fuss here. If you put the specified amount in it will come up to the bottom of the filler hole anyway. So filling until it spills or just putting a measured amount in it's the same amount of oil either way. The only way to get more in would be to jack the back of the car up at about 45 degrees and fill the box up.
It's tilted back. As the whole engine/transmission assembly is mounted nose up, to allow the axle to clear the bottom of the engine (they made a mistake with that on early Pumas too, they had to fit a revised sump!) If you think about it, the oil in the box will still try to remain level, which means the oil will run out of the filler hole slightly sooner, meaning a marginally lower oil capacity. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17698 ![]() ![]() ![]() |
If you drain the transfer box in the conventional way, then remove the transfer box from the vehicle, take it into your kitchen (because it is raining hard outside) and dismantle it completely for rebuilding, a surprising amount of oil will appear as though by magic on the kitchen floor. Experience suggests that this also tends to get you into considerable trouble with the Domestic Authority, even if you wait until she is out before doing so. The aroma and mess of the oil means that she will detect that you have been "up to something" with a perspicacity which is uncanny. ![]() |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello zsd-puma...have you actually done this, or seen this done... ![]() I didn't when I changed All Oils at 28K... It would be interesting (for us anyway... ![]() I'm only 6K past an All Olis change...(but have enough to check / re-new the Transfer Box) So the next time I see... ![]() Click image to enlarge I'll use my D2N Inspired Oil Dispenser ( ![]() ![]() ![]() Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html Last edited by X4SKP on 20th Sep 2017 2:29pm. Edited 1 time in total |
It comes in 1ltr bottles with a (roughly) graduated sight gauge on the side of the bottles. When i filled mine to spill fill, it used two complete bottles and approx 1/3rd of the 3rd bottle. Allowing for residue left in the syringe and the spillage from the filler this is as near as damn it the capacity quoted for the transfer box. So again just fill it until it runs out of the filler hole..... ![]() |
Thanks zsd-puma (sorry for the mis-spelling)
I had only seen the TB Fill instructions (until now) described as 'Fill to Filler' and currently I think you (and others) are right, this is the way to do it... Either way... next time round i'll measure what goes in until it 'Spills'... ![]() ![]() Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
Milmur64 Member Since: 05 Oct 2016 Location: Perthshire Posts: 33 ![]() ![]() ![]() |
My 2015 Defender has clocked 13,800 mikes over the past couple of years and I have just changed the gear and transfer box oils today. Followed the advice re: gear box and measured exactly 2.2 litres including circa 10 ml for residue left in pressure vessel.
When I changed the transfer box oil I measured the oil that came out. When I first took the filler plug out it literally poured out which took me by surprise which suggested it was overfilled but how this was achieved is beyond me. The approximate quantity of waste oil collected was 2.5/6 litres. When I came to fill the box it took 2.6 litres until it over flowed from the filler plug? Everyone appears to quote circa 2.3/2.4 litres so I was concerned at the amount of oil required to reach the bottom of the filler plug. Obvious question is have I over filled it and will this potentially cause me a problem? Easy enough to rectify - any advice would be appreciated. |
Was the vehicle parked on level ground when you filled it?
Yes it was - the other information was I have just had the LR
24k or 2 year service and the Service record showed topped up Transfer Box oil so maybe dealer tipped the vehicle forward to level out the known tilt of engine? |
