Home > Off Topic > As you guys are clever chaps
mse
On a Range Rover (or Disco)
Do you get the green padlock appear if you dont have the e-diff on the rear diff? Mike
Post #65105 25th Mar 2011 8:18pm
mrandmrsh
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
On a D3 yes you see both padlocks but the rear one never goes orange showing it is locked if you don't have ediff fitted.
Some folks report it showing locked when you go into rock crawl + low range but my d3 has only ever shown rear ediff locked when it needed to be i.e. when off road. On disco3 there's instructions on how to check but basically the easiest way appears to bs to look for the actuator motor atop the rear diff.
HTH
Craig
Post #65108 25th Mar 2011 8:31pm
Lookers Park Royal
Mike,
If you give me the last 6 digits of the chassis then I can check it for you tomorrow. No easy way to tell without getting it muddy or jacking it up!
James
Post #65109 25th Mar 2011 9:18pm
mse
Thanks all James had a look - it might not have it.
But i am going to check as i a few options werent listed and i would like to know why the symbols did their thing! Mike
Post #65181 26th Mar 2011 8:24pm
