![]() | Home > Off Topic > As you guys are clever chaps |
mrandmrsh Member Since: 31 May 2010 Location: Huddersfield Posts: 692 ![]() ![]() ![]() |
On a D3 yes you see both padlocks but the rear one never goes orange showing it is locked if you don't have ediff fitted.
Some folks report it showing locked when you go into rock crawl + low range but my d3 has only ever shown rear ediff locked when it needed to be i.e. when off road. On disco3 there's instructions on how to check but basically the easiest way appears to bs to look for the actuator motor atop the rear diff. HTH Craig |
Lookers Park Royal Member Since: 19 Jun 2008 Location: London Posts: 338 ![]() ![]() |
Mike,
If you give me the last 6 digits of the chassis then I can check it for you tomorrow. No easy way to tell without getting it muddy or jacking it up! James |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5060 ![]() ![]() ![]() |
Thanks all James had a look - it might not have it.
But i am going to check as i a few options werent listed and i would like to know why the symbols did their thing! Mike |
