Home > Puma (Tdci) > 2.4 2007 Rough idle worse in cold weather
Page 1 of 3 123>
jst
I have searched here and tried on another post but not sure its had much exposure lately so after some help with a new post.
Vehicle is running well no other problems 28/29mpg which is normal for it.
On a cold engine start the idle is lumpy, similar symptoms to a load being applied to the engine (like AC going on but a higher load) engine rpm drops a 100rpm then fluctuates a bit. it does this until warm at idle and low engine speeds ie moving down the drive.
Once warmed up it runs and idles fine, subsequent resatrts when hot/warm it doesnt do it
This morning was the coldest morning we have had in a while and it was lumpy enough to almost stall the vehicle (but it caught itself)
on other threads the VCV and fuel pressure valve are mentioned, how can i check them and would they be affected by ambient temp? ie lower the ambient the worse the cold idle is.
I dont have a means for live data reading. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #650280 14th Sep 2017 1:59pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Have you tried reading any codes? I'm certainly no expert but I'd not be surprised if you had a glowplug issue.
Post #650311 14th Sep 2017 4:19pm
jst
no, working on that. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #650348 14th Sep 2017 7:28pm
Try this, it should at least clean everything through.
http://www.opieoils.co.uk/p-60222-millers-...tment.aspx WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #650349 14th Sep 2017 7:30pm
jst
ok, will do, whats the thoughts on adding 2 stroke to it for same effect? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #650354 14th Sep 2017 8:03pm
Bluest
I don't know a way you visually check those valves. On mine, a diagnostic tool shows the fuel pressure fluctuating wildly. I have the same problem, suspect the VCV, but as it doesn't do it when it's warm it's not bothered me for a few months. I'll now doubt be contemplating changing the VCV again in a few weeks. 2007 110 TDCi Station Wagon XS
Post #650355 14th Sep 2017 8:05pm
jst
Bluest, so yours has exactly the same symptoms? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #650360 14th Sep 2017 8:11pm
Bluest
I have lumpy fluctuating idle in winter when the engine is cold. It occasionally happens when warmed up, but to a lesser degree. Virtually never happens in warmer weather, if it does it is much less severe. Using Millers Dieselmax additive seems to alleviate the problem a little.
My theory, and it is only my theory, is that the piston in the VCV gets dirty or corroded and starts to get sticky. For some reason temperature and/or the extra lubricating properties of the additive alleviate it to some extent.
I have a new vcv to go on but I haven't done it because just because I haven't got the tool needed to programme a new one, I forget how annoying it is and I've been busy. 2007 110 TDCi Station Wagon XS
Post #650364 14th Sep 2017 8:22pm
I had similar last winter also but haven't seen it as much to worry about.
Again likely the VCV but the programming is a pain in the backside so I see that point of view..
I think it's likely that in the winter the diesel waxes more and everything inc as suggested above the VCV workings become more sticky.
Diesel also has different additives in the winter I believe due to possible freezing temperatures. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #650368 14th Sep 2017 8:33pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Same issue here...
I've been considering changing the VCV as well, now that the Nanocom (version 1.33) has support for "pump learning" for the Puma 2.4 (< 2012).
Has anybody used these (new) features in Nanocom, pump and injector pilot correction learning?
(injector pilot correction learning was added a while ago whereas the pump learning is a brand new feature in Nanocom software v1.33) β€œA Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #650413 15th Sep 2017 8:18am
Bluest
That's grabbed my attention! I have a Nanocom. How did you find out and how do I upgrade mine? 2007 110 TDCi Station Wagon XS
Post #650415 15th Sep 2017 8:54am
o4dn
I've found out in the release notes for the new version, I've been waiting for ages for this feature to be added Smile
The Nanocom forum also has some discussion about that feature and where it was added (was not obvious at first in which menu entry it was to be found...)
Nanocom forum is here: http://forum.nanocom-diagnostics.com/
You can get the SW update from the restricted area:
https://www.nanocom-diagnostics.com/restricted
Additional information (and how to upgrade) can be found either on their forum or in the documentation (including videos)
Post #650417 15th Sep 2017 9:01am
Bluest
Thank you, I'll check that out tonight. 2007 110 TDCi Station Wagon XS
Post #650419 15th Sep 2017 9:38am
M94PUMA
Change the vcv, THEN do the pump re-learn & injector pilot correction. This will most likely solve the rough idle, if your glow plugs aren't working well it will rough idle for 10 seconds odd after starting cold and then should pick up as normal.
I have the BAS2 RRC tool and can do the pump learn and injector correction in a matter of minutes from my iPhone.
My very quick review of the vcv change..
http://www.defender2.net/forum/topic55914.html
Post #650503 15th Sep 2017 7:26pm
jst
looks like i may be on the scrounge for a nanocom then! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #650504 15th Sep 2017 7:27pm
Page 1 of 3 123>
