![]() | Home > Puma (Tdci) > 2.4 2007 Rough idle worse in cold weather |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8205 ![]() ![]() ![]() |
LR one http://www.brit-car.co.uk/product.php/2214...ure_relief
Transit one http://www.ebay.co.uk/itm/251563342126 Both for 2.4s would they be the same...? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
M94PUMA Member Since: 16 Dec 2016 Location: Hampshire Posts: 151 ![]() ![]() ![]() |
It's not essential but highly recommended to get it re learned and pilot corrected
well i was going to do the whole job and get a relearn, but when i phoned for a price for the learn i was told it didnt need it hence the post.
Whose fitted one and not done a relearn? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17698 ![]() ![]() ![]() |
It will run without a relearn, and if the old VCV was faulty it will run better with a new one. Given time it will relearn by itself, but the higher the mileage the longer it takes.
ok, thank you, so may well be fitting the one i have here and not doing the relearn. if it runs better i know the old was faulty and can then either pay to match it or let it sort itself out. thank you. Cheers
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4255 ![]() ![]() ![]() |
Damnation! Just discovered I need a Windows PC to do the upgrade, I've got an old Mac. Need to find someone with a PC I can use. 2007 110 TDCi Station Wagon XS |
I have gained access to a code reader and am repeatedly seeing p0404, p0100 and p1103. EgrFault causing the maf problems or both at fault? Cheers
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20718 ![]() ![]() |
EGR causing MAF readings to be thrown out most likely.
Likely culprits is EGR only. WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
cheers, so will that cause the rough cold idle too?
solution is change the egr/clean it or could it be mapped out and blanked? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
schuee Member Since: 16 Jul 2012 Location: Lincolnshire Posts: 378 ![]() ![]() ![]() |
I was experiencing exact same symptoms, rough idle and kangaroo juice thrown in when cold weather which cleared after engine warmed up, I had VCV replaced and pump and injector pilot relearn carried out and this cured the problem 100%
![]() Cheers Keith MY2011 110 XS USW |
thank you
have a consistent EGR fault currently so am going to sort that then if persists looks at VCV change. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
EGR issues can pose similar issues as the VCV.
The symptoms Keith describes above were the same for me when I had EGR stuck closed issues. I myself went for an Alive stage 1 EGR shut down and blanked. In fact my EGR there now is faulty but shut right off. I bought a new EGR to replace and packed up 6 months later £160 down plus my own Labour. ![]() Cleaning them seems very hit and miss, I never tried as I didn't think it would be reliable anyway. WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
i am probably going for the Alive software off for the EGR and be done with it. Did you blank yours too? Cheers
I did indeed, to be on the safe side.
You can slip it in from the side and torque figures are somewhere in my gallery or on here. WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
