![]() | Home > Td5 > Turbo actuators |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5890 ![]() ![]() ![]() |
While mooching around I spotted this for sale
http://www.ebay.co.uk/itm/Land-Rover-Defen...SwmgJY743L Not seen many knocking around for sale, they all appear to come with new turbos. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2193 ![]() ![]() |
They can rot out and the diaphragm can fail, not often but it does happen.
JustFX Member Since: 10 Nov 2016 Location: Mendip Hills Posts: 190 ![]() ![]() ![]() |
I have heard of them becoming stiff to move. I have a posh s/s one to fit (removed from my TD5 Disco)
https://www.forgemotorsport.co.uk/Adjustab...-1033.html ![]() |
How stiff is too stiff? 1999 Defender TD5 110
In replacing the actuator it would be hard to say if it made any noticeable difference for you then given you had a cracked piston 1999 Defender TD5 110
I drove with a rather knackered engine for a year before it got to the point where I said...bye.
There was a lack of power at times, turns out the oil system was pressurising causing a lack of oil to the turbo and that meant I killed a turbo eventually. I was trying cheapest options first as I had spent a fair bit on the LR over the years I had it. ![]() |
