Home > Td5 > Glow plugs.
roel
Glow plugs.
My 2003 90 td5 needs a little more time to start. I know that I have not been nice to my batteries lately, winching them almost flat.
However it looks like I have a glowplug problem.
They are a bit off a pain to get to but it looks like the front 2 have a very high resistance, the 3rd has a rusty top as the plug was not nicely put down on it. Evil or Very Mad The fourth one looks ok with a measured resistance of around 4-7 Ohm.
As I think the first 3 are not that good I didn't bother looking for the fifth. Whistle
What should be the resistance off a good glow plug?
How do you get them out? And what size socket do you need, 11mm? It is hard to get to with the inlet manifold. But the workshop manual doesn't tell you to remove it. Roel
2003 90 Td5 (2009-now)
Post #649595 11th Sep 2017 4:28pm
miker
For the cost of them, I'd probably just replace all 4. (And yes I mean 4, there isn't a fifth!)
From memory they are just a bit fiddly to get out, inlet manifold improves access, but obviously means you have to pull the manifold!
Post #649605 11th Sep 2017 5:04pm
excossack
A long reach socket and an extension and I can manage them.
I normally get the engine warm first to aid removal. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #649618 11th Sep 2017 6:27pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
As stated, yes there are only four so don't look too hard for a fifth one. The fifth was, during the design process of the Storm motors, deemed to be unnecessary. Just change em all. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #649726 12th Sep 2017 1:29am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
From my experience, glow plugs in TD5 engine are not really needed - TD5 was to only car that started 2 years ago in winter, when it was below -25°C outside. With engine running, I had to jump start more than 10 neighbours cars, mostly petrol powered. TD5 started, but not perfectly on first turn of engine, so next day I have measured current to glow plugs (with clamp meter), and to my surprise, it was 0 Amps = no working glow plugs.
And for sure, I have good charged battery, as big as possible, and the glow plugs were replaced. "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #649736 12th Sep 2017 7:27am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
+1 I don't even wait for the glow plugs, I'm not even sure if they work because I had a problem with another relay(I think it was fuel pump) and swapped them over about 3 yrs ago. I've been meaning to get another one since. It starts better than my wires tdv6 disco and all the plugs work in that! 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #649789 12th Sep 2017 11:04am
4RF RDS
The Td5 is agreat engine and does in fact start very well in rather cold climates. The issue with non functioning glow plugs is that you get poor mileage and sub optimal performance if the relay or units themselves are not working. The glow plug system in the Td5 actually will work continuously (on) while the engine is runnung until the coolant comes up to operating temperature and only then will they shut off. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #649795 12th Sep 2017 11:20am
roel
I thought most of you would understand the joke that I didn't bother looking for the fifth. Laughing
It is starting a bit better now the connector to the third glowplug is connected, so 2 working instead of one. Razz
I am planning to change all 4 off them however I might need to get the inlet manifold off as a socket with my short extension is to short to get my ratchet on and my longer extension won't fit between the socket and inlet manifold. Roel
Post #649801 12th Sep 2017 11:43am
roel
Where do you fit the 5th one?
http://www.ebay.co.uk/itm/5x-Bosch-Glow-Pl...SwB09YHM6H
Mr. Green Roel
Post #650892 17th Sep 2017 10:34pm
4RF RDS
Rolling with laughter you get a spare cause at least one will fail on you right after install. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #650893 17th Sep 2017 10:37pm
roel
Coming back to this thread: Changing the glow plugs helped a little but not much. So I tried the battery from my D3, that didn't help either
So I tried to test the battery cables by laying a jumper cable next to it, That didn't help either so the only thing else must be the starter motor. I did really think that would be the problem as it started always but needing 20 seconds or more if it was n't used for 12 hours or more. After 6 hours or less it started quickly.
So I didn't think the starter motor would be the problem but it was. A td5 startermotor is not waterproof and as I use it off-road I know I have to clean it sometimes. This time when I took it out it was very difficult to turn it by hand. Even when I had the motor part apart it turned very difficult so I took the gearing part apart and the grease in there was more or less solid. I cleaned it out and put some new grease in there and now it starts within a second.
I didn't expect that grease could have that effect. Roel
Post #657319 14th Oct 2017 10:19pm
