Home > Maintenance & Modifications > Fitting Roof Rack Spot Lights - Puma 110
Page 6 of 6 <123456
PaulMc
OK, I see what you have Thumbs Up
STC53208 is for a TD5 Defender, and the Blue/Orange wire from the relay goes to behind the instrument pack to pickup the main beam warning light, which is also on a Blue/Orange wire.
On a Tdci Defender, the main beam warning light is on a Blue/Grey wire (shown as US (Blue/Slate) in the wiring diagrams).
So you need to take your Blue/Orange wire and splice it to the Blue/Grey wire at the back of the instrument pack, on C1040L-27
. Paul.
Post #318669 24th Mar 2014 12:13pm
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
…as usual Paul has wright !!!
Thank you Paul Bow down www.newfoundland.gr
Post #318697 24th Mar 2014 1:46pm
supercamel
[quote="PaulMc"]
BruceT wrote:
Hi Paul,
Been batteling with this as I dont want to rip out all the wiring I have already done. Can I wire the switch up like this:
Pin 1 = 12V+ power in (on with parking lights)
Pin 2 = Switch illumination
Pin 3 = Earth
Pin 4 = Switched power out (to driving lights relay)
Pin 5 = 12V+ supply for telltale (from the driving lights when on)
Thank you.
Hi Bruce,
No, you can't wire the switch like that, for two reasons -
1: The Illumination and Tell-Tale are LEDs and will only work in one direction.
2: Pin-3 and Pin-4 are commoned.
However... Smile
You can easily modify the switch's internals to make it switch as you want Thumbs Up
This is what the switch looks like inside (bad photo alert Embarassed )
Here's a picture of the inside of the switch, which I've annotated with the terminal numbers and to show how the contacts connect accross pins 1 & 4 when in the ON position -
This is a close-up of the switch's circuit -
It's easy to convert this switch to a conventional live switching ON/OFF switch by cutting the brass track between the two holes, as marked in red in this next picture (I've use a Needle File to do this on the ones that I've modified) -
By cutting the track at this point, you separate pins 3 & 4
The revised circuit is now -
Pin 1 - Incoming Live from Main Beam/Dipped Beam/Side Lights (as applicable)
Pin 2 - Live from Dash Illumination
Pin 3 - Switch Earth (for indicator LEDs)
Pin 4 - Switched Live output to Terminal 86 of your Relay
Pin 5 - Live in from Pin 4 (for Orange 'tell-tale' LED)
You could link pins 4 & 5 inside the switch while you had it apart, by soldering a link across the brass tracks but I would just crimp an extra short length of cable into Pin 4 and loop it round into Pin 5 on the connector.
You will still need to use an accessory relay with a switch modified in this way but, at least it will be wired in a conventional manner.
Paul.
Hi
Can anyone help with the converted switch method above?
I have fitted a wiring loom which has a relay etc to power 4 led spots however this came with a fitted 3 pin toggle switch. I have managed to convert the switch as described above which does function correctly to turn the spots on and off. I can't however get the orange tell tale light to function when the lights and switched on.
From the 3 pin toggle I have a spare wire which I believe is the switch earth. This runs into 85 on the relay. Not sure which pin this if any it should go into on the converted YUF500150LNF?
I have tried linking pin 4 and 5 wire a short bit of wire however still can't get the led to glow which the lights are on.
Any ideas anyone?
Post #600207 8th Feb 2017 9:04pm
DEF110DCPU
Belgium 2008 Defender 110 Puma 2.4 DCPU Stornoway Grey
is it possible to put the wiring diagram images for the YUF500150LNF again but with another program because photobucket doesn't show them anymore?
Post #649455 10th Sep 2017 8:34pm
Bluest
Is this any use? Just used it to wire mine.
 2007 110 TDCi Station Wagon XS
Post #649467 10th Sep 2017 8:57pm
DEF110DCPU
hello, thank you very much!
does anyone have the same diagram but for the YUF500150LNF switch?
Post #649510 11th Sep 2017 5:51am
DEF110DCPU
Okay did my first Paint job ever Razz Laughing Whistle
Who can tell me if that is the correct wiring diagram for the heated seat switch YUF500150LNF to led bar?
Post #650129 13th Sep 2017 4:53pm
Coatesyyy
Great tips an photos for the wiring! Thanks Thumbs Up
Post #650256 14th Sep 2017 11:11am
DEF110DCPU
Caution, my input with the last wiring diagram isn't approved by experts yet, so please don't use it before some one says GO Smile
Post #650290 14th Sep 2017 1:51pm
GrahamGParker
2015 Defender 110 Puma 2.2 USW Corris Grey
test
Post #651352 19th Sep 2017 6:17pm
GrahamGParker
The Boy wrote:
Wiring the roof lights and roof mounted auxiliary plugs.
OK so for the route for the roof lights I exited through the rear of the battery box under the middle row floor and back in just behind the middle seats.
This is a great how to thank you I'll be checking on it again when I do mine. One question. Am I correct in saying that the feed for the spots came out of the rear. How did you get it to the spots at the front? Did you cable tie it to your rack
Post #651359 19th Sep 2017 6:21pm
DEF110DCPU
okay, someone told me the wiring diagram is correct!
Post #654865 4th Oct 2017 1:21pm
DEF110DCPU
okay, yesterday evening I did the test according to the wiring diagram, led bar to switch YUF500150LNF heated seat switch, and everything works in perfect order!
Post #656479 11th Oct 2017 6:58am
Page 6 of 6 <123456
