Home > Technical > temp gauge volts.
carmi
United Kingdom 1996 Defender 110 300 Tdi USW Alaska White
temp gauge volts.
what is the voltage to temp gauge with engine running,? any body help.
Post #649402 10th Sep 2017 6:06pm
dorsetsmith
12.7 to 13.8 v i.e. battery charge voltage to start with
Post #649405 10th Sep 2017 6:11pm
carmi
Thanks M8 ,I have a 300tdi 1996 defender running at 14.5 volts .gauge in the red after one K. From pump to gauge all new. next thing to check will be the printed circuit. Open to idea`s.
Post #649409 10th Sep 2017 6:22pm
dorsetsmith
witch sender do you have fitted as three types green, black, red
https://forums.lr4x4.com/topic/41022-temp-gauge-problem/
Post #649411 10th Sep 2017 6:28pm
carmi
black new one. Engine not over heating, thermostat opening at 94/95 .
Post #649414 10th Sep 2017 6:44pm
dorsetsmith
Is the gauge going in to the red all time ? with power to the temp gauge
Post #649473 10th Sep 2017 9:03pm
carmi
Hi, good morning, Yes it is all the time . it looks like I will have to spend that £170 for a new printed circuit, just hope it works. Thanks for looking. Just found out that it could be Resistor in line from the alternator. any one know where it is, save me from ripping my landy to bits. thanks.
Post #649527 11th Sep 2017 8:33am
carmi
Well I found the info that I wanted , on Ihsw .com electrical library. PdF. Now to get an other temp, gauge.
Post #650072 13th Sep 2017 12:31pm
dorsetsmith
if you dis cornet wiring to the sender at gauge is the gauge go in to the red when power up, if it remains at 0 you have a short to ground in the wiring to the sender
Post #650073 13th Sep 2017 12:41pm
carmi
Thanks guys for the help, I`v run a wire to earth from gauge body. It has come off the red and is now siting on the half way mark.Will take it for a run later and let you know how it runs.
Post #650422 15th Sep 2017 8:50am
carmi
Well that seams to work, did a 3k run and the gauge sat just to the left of half way. don`t know how it works but here`s hoping it say`s that way. well keep you informed.
Post #650621 16th Sep 2017 12:48pm
carmi
Did a good run yesterday 30 miles, gauge stayed on same spot, just befor half way. Don`t feel right , just keep looking , onwards and upwards.
Post #651486 20th Sep 2017 10:33am
dorsetsmith
you can check temp gauge with power in to the gauge remove sender wire short it ground gauge needed shod go full scale and with the engine up to temp remove sender wire needed shod go to (0)
Post #651517 20th Sep 2017 1:31pm
carmi
Thanks Smithy i will give that a try when it`s up to full temp.
Post #651582 20th Sep 2017 6:04pm
carmi
HI guys, Just an update on the high temp reading on my 96 110. after putting in new senders and temp gauge it sill was reading high,( in the red) so I thought Censored this, Got my self a cheap Chinese one with a earth. Just done 10 mile run, worked fine went up to 94/95 and sat there, thermostat opens at 95. Very Happy Very Happy
Post #652645 25th Sep 2017 1:03pm
