Home > Technical > Pre and post 1997 licence trailer towing clarification.
Page 2 of 2 <12
JWL
Here's a bit of a question for the Guru's, if you look at the licence codes for those of us who passed our test some years ago then you can drive a vehicle up to 3500kg MAM plus a trailer up to 3500kg, ie the full capacity on BE.
On C1E Vehicles between 3,500kg and 7,500kg carrying no more than 8 passengers plus driver with trailer over 750kg, if combined vehicle and trailer weight isn’t more than 8,250kg because of the restriction 107
Then take a look at D1E, Vehicles with up to 16 passenger seats plus driver, with trailer over 750kg also with a restriction which are 101 not for hire or reward (that is, not to make a profit), 111 limited to 16 passenger seats and 119 weight limit for vehicle does not apply.
If you're not bored yet, take another look at the restriction code 119 weight limit for vehicle does not apply. So could that mean that the towing vehicle could carry up to 16 passengers and tow anything behind (subject to manufacturers specifications) so we can't go over the 3500kg with a Defender, that's the manufacturers limit but get a large minibus and the sky's your limit!
Post #649060 8th Sep 2017 7:50pm
miker
I think +E is classified as a trailer up to 3500kg across the board?
Post #649061 8th Sep 2017 8:00pm
JWL
Fair point. I do remember in the dim and distant past that my C1E part stated that I could drive a 7½ tonner with a trailer with a GVW of 11¼ tons, note the imperial weights as it was a while ago. I'm sure I've seen a figure of 10.250 tonnes mentioned in the D1E catagory but I can't be asked to trawl around because I'm sure the powers that be would find some technicality to slap your wrist Whistle
Then there's allways the "n" catagory, Vehicles (exempt from duty). Limited on distance but the sky's the limit Whistle
Post #649066 8th Sep 2017 8:27pm
zsd-puma
+E means you can tow a trailer up to the maximum weight the tow vehicle can legally tow. Basically it means there is no licencing restriction on trailers. I seem to remember there being something on a B+E licence about a 12tonne limit on either train weight or trailer weight. But the likely hood of you finding a 'car' or a commercial vehicle uner 3.5tonnes that can tow that sort of weight are slim. Which means in practice on a B+E you can tow what ever you like so long as the tow car is rated to tow it. Anything heavier you're likely too need to take another test to add cat C1 (7.5t) or C to your licence anyway.
So yes on a Defender that's 3.5t with overrun brakes or 4t with coupled brakes (air brakes).
I have an HGV and PCV licence, because i did C+E (HGV with trailer, the old class 1), it also upgrades my car and bus licences to +E too, it gives me B+E, C1+E, D1+E, C+E and D+E
So i could have a 10tonne tractor unit with a 34tonne trailer on the back. Or a 15metre long coach with a 6tonne trailer on the back. But that's just standard configuration vehicles. If you get into abnormal loads there's basically no weight limit, but it starts to get even more complex involvling the number of axles and whether it has 'road friendly' suspension.
Post #649070 8th Sep 2017 8:51pm
^^ Quite right. C+E allows you to run up to 44 tonnes gross under C&U Regs or 150 tonnes gross if operating under STGO Cat 3.
Post #649076 8th Sep 2017 9:32pm
zsd-puma
I just checked, and you can even go above 150 tonnes if you get special permission from the Department of Transport. Though you'd need to justify why you couldn't split the load into smaller chunks. There isn't much you'd move by road that weighs more than that and can't be broken down. Railway Locos are probably the heaviest you'll find. Ours are 132t, but they take the bogies off when they go back to Loughborough for refurb So they're probably only about 100tonnes ish, plus the lorry.
Still no 'special' driving licence required even for that, just a normal C+E. But that doesn't mean they're going to phone the nearest agency and get any old C+E driver to come and drive it. Laughing
Post #649080 9th Sep 2017 1:11am
miker
Big power transformers are the main thing that gets really heavy I think
Post #649145 9th Sep 2017 3:41pm
zsd-puma
Yeah I was thinking really heavy stuff is usually for powerstations and the like.
A Defender would definitely need a new clutch after moving one of those. Laughing
Post #649147 9th Sep 2017 3:44pm
150 tonnes is the max on an STGO. There is no upper limit once you get into the world of individually authorised movements and it's still C+E to drive.
I think the UK on-road record is a load out of Didcot power station moved by Allely's but can't remember the weight.
Site moves, especially for the oil industry, can be well over 1000 tonnes.
Edit - it was 640 tonnes, link to rather gormless article in Daily Mail: http://www.dailymail.co.uk/news/article-25...-4mph.html
Post #649327 10th Sep 2017 1:05pm
zsd-puma
I'm not sure you can rely on the DM's accuracy about anything. Laughing
But anyway, the point is +E lets you tow quite a bit over 3.5t. Thumbs Up
Post #649501 10th Sep 2017 11:24pm
Page 2 of 2 <12
