Home > Technical > Tilted
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Tilted
Defender is leaning to the driversside (LHD). Replaced springs and shocks, with no change. Articulation is 2-3 cm less on the rear left side.
What else could be the reason?
Post #649110 9th Sep 2017 8:59am
mse
are the springs handed on the puma - im sure they used to be and on the discos.
If not then were they all the same etc? Mike
Post #649119 9th Sep 2017 10:56am
Whirly90
England 1993 Defender 90 300 Tdi HT Keswick Green
I had the same problem, turns out the front springs were on the wrong sides. The rear ones were fine but just having the front ones the wrong way round managed to tilt the whole truck, i swapped them over and it sat perfectly square.
Post #649120 9th Sep 2017 11:00am
mse
I thought they were handed...clearly they are - the rears arent, just the fronts from memory Mike
Post #649123 9th Sep 2017 11:35am
zone30
Not the problem: it was fine before, then one day I had the issue, before the spring and shock swap. Must be domething else.
Post #649133 9th Sep 2017 2:09pm
X4SKP
Hello zone30
I measured mine when I got it as I noticed a slight variation (admittedly not as great as yours)
Front measured the same, the Rear was around 10mm lower Drivers Side (RHD)
I thought this could be as this side has the most loading, as it always has weight on the Drivers side
I found this chart...which I took to be right...
My 90 is as follows (4 seat station wagon, 2550 Kg)
Front - Driver's side REB500200 Red/Green/White
Front - Passenger side REB500220 Red/Green/Orange
Rear - Driver's side RKB500270 White/Green/Pink
Rear - Passenger side RKB500270 White/Green/Purple
Around 3 months ago I fitted Spring Isolators both top and bottom giving a 20mm lift overall
I noticed that the rear off-side spring was 180 degrees 'out' in comparison to the others, so for
'symmetry' I rotated it whilst fitting the Isolators. She now measures better halving the discrepancy so
<5mm difference now, and I see that you can buy 6mm Spacer Discs for correcting these small amounts.
I was told, but others may know more here, that LR use to vary the Spring Rating, like the chart, but towards
the end they moved to a common Spring on both sides of each axle at the rear, for some models, mine is different on all corners, I guess to level out the weight loading to give a 'flat' vehicle.
Is is difficult to see what your issue is if you have replaced both the Springs and Shocks...
If your Defender was once right, and now it isn't, and your replacement Springs are rated / installed correctly
then maybe...and this is a long shot... try revering the Rear Springs and see what you get. It may proved that the Springs and their rating, is the significant factor here (even if you still don't end up with a level Defender).
Or you may get lucky...(Good Luck Thumbs Up ) SKIP
Post #649139 9th Sep 2017 2:32pm
mse
Is difficult if you are saying before touching a spring it changed and dropped thats very odd.
the defender suspension is reasonably simple.
Shocks wont make much to any difference, springs impact height so unless somethings broken or missing im not sure what it could be - i assume you have checked everything is seated correctly nothing is broken etc.
All the leading and trailing arms are ok etc? Mike
Post #649156 9th Sep 2017 4:31pm
zone30
Can't see any issue. Leading and trailing arms are my suspects now but don't see anything special really.
Someone suggested I might have bent one?
Post #649163 9th Sep 2017 5:01pm
zone30
Which ones to buy: I see HD versions with a cranked end. Also with different chassis connections.
What to buy (standard 110 from 2011)
Post #649171 9th Sep 2017 5:43pm
sgreenham
United Kingdom 2010 Defender 90 Puma 2.4 HT Galway Green
Just resurrecting an old thread because I have this issue with my 90. It sits about 3cm lower on the rear passenger side compared to the rear driver's side. I've had a look for the colours shown in the chart above. Mine is a 90 Hard Top and I have;
Rear Passenger Side - White markings
Rear Driver Side - Red Markings
Front Driver Side - As far as I can make out it has one white 'blob' on the spring
Front Passenger Side - I can't see any colouring at all.
When I look at the table above I see there is a selection of colours show for each spring, why is that?
Also everything looks ok and, for what it's worth, it's just passed an MOT so there shouldn't be anything loose.
Does anybody have any idea what the issue could be? I'm concerned that, because of the inconsistent markings on the front springs, maybe that could be the cause because the rear springs have plenty of coloured markings on each spring?
Post #771628 5th May 2019 3:17pm
sgreenham
Can anybody help with this?^^ I'm wondering whether I should change the front springs just incase they aren't genuine/correct? Or is there a way I can easily find out if they are genuine/correct.
Post #771838 7th May 2019 6:21am
Bluest
Where it shows multiple colours the spring should have a blob of each one on it I think. 2007 110 TDCi Station Wagon XS
Post #771844 7th May 2019 7:22am
sgreenham
Ah ok, I'm not convinced any of mine have that. I'll have to have another look.
Post #771845 7th May 2019 7:25am
sgreenham
My rear ones look like this...
Post #771847 7th May 2019 7:30am
X4SKP
For example (Before Dinitrol Coating)
My Rear - Driver's side RKB500270 White/Green/Pink
 SKIP
Post #771848 7th May 2019 7:30am
