![]() | Home > Puma (Tdci) > Dash switches - can the locations be swapped? |
myonehere Member Since: 03 Mar 2009 Location: Worcester uk Posts: 153 ![]() ![]() |
Yes -they are ''keyed''' ... but a quick slice with the Stanley Knife sorts it...
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 392 ![]() ![]() ![]() |
perfect.....thanks.
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
As above regarding the keying, the other limiting factor might be the cable length. It depends which ones you want to with each other, but you might have to extend the wiring a little
Hendrix Member Since: 04 Oct 2016 Location: North Notts Posts: 106 ![]() ![]() ![]() |
I have a blank on the top left switch position. Can you get a switch for here without the symbols or with a different light symbol. Do any models use that position. Is there any wiring already in the loom?
I want to add some extra lights and would like to use that position. |
greenlandrover Member Since: 09 Jul 2017 Location: Stourbridge Posts: 145 ![]() ![]() ![]() |
It's normally taken by an auxiliary light switch YUG000540LNF
![]() Click image to enlarge Later models have a stability/traction control switch here I think??? When you fit aux lamps to a vehicle with this switch present you have to cut the dash to suit as per VPLDV0103 instructions: - ![]() Click image to enlarge ![]() Click image to enlarge |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6661 ![]() ![]() ![]() |
The other option for a DSC equipped Defender (and if you never use the DSC switch) is to relocate the DSC switch inside the dash, freeing up its spot.
Found a full copy of the instructions thanks, I have a blank the left of the three so shouldn't need a hole. Local dealer couldn't even find a different switch for me.
