Home > In Car Electronics > 5.25" speaker upgrade |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1432 |
Yes fitted Focal K2 power in both a puma and td5 no adapters necessary. Passenger side requires a bit of tapping with a hammer to sit flush, other than that relatively simple
Click image to enlarge Click image to enlarge Click image to enlarge Old photos showing focal shallow mount KRS, but been upgraded since to K2 powers |
5th Sep 2017 7:12am |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
Did you have to cut bigger holes? Those speakers are pricey the Pioneers I found look to have a mounting depth of about 46mm
http://caraudiosecurity.com/ts-g1333i-3-way-coaxial-speakers-250w |
5th Sep 2017 9:11pm |
They are but it all depends what you want ?
Yes you have to enlarge the holes slightly, but its relatively simple. IMO you wont gain much swapping to those pioneers. You'd gain more buying components than coaxials. A set of genuine puma take outs will probably sound better, with the highs above the dash Click image to enlarge |
6th Sep 2017 10:24am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
If necessary you can get spacer rings if new speakers are slightly deeper. For example http://farcorners.co.uk/product/shallow-sp...ngs-130mm/ James
6th Sep 2017 11:18am |
how hard is it to fit some components then? ie would i need to take dash apart to hide the cross over box?
6th Sep 2017 11:43am |
im not after anything pricey but what i have currently is awful but im no expert on car audio so recommendations welcome |
6th Sep 2017 11:54am |
See the for sale section http://www.defender2.net/forum/topic56814.html James
12th Sep 2017 9:40pm |
