Home > Puma (Tdci) > dubrywotsit thingummyjig - sorted! |
24heuer Member Since: 21 Jul 2015 Location: Edinburgh Posts: 167 |
Hi all,
Anyone know the part number for this clip? It's under the fascia finisher above the instruments and where the torx screws attach to. For some reason one of mine is mia/awol... Was used to a vehicle made up of a pick'n mix of fixings and screws on the 300TDi but wouldn't mind keeping the Puma original if possible. Thanks, Cheers, Andy... Edinburgh, Scotland http://24heuer.com Last edited by 24heuer on 13th Sep 2017 6:27am. Edited 1 time in total |
3rd Sep 2017 4:12pm |
Not available seperately from Land Rover, it's supplied as part of the dash assembly.
However i think you can get the same part from BMW, it's used on the Mini's. Alternatively these are the people who made the Dashboard for Land Rover at their Hartlip (Kent) factory. http://www.grupoantolin.com/en/contact-info |
3rd Sep 2017 7:47pm |
Ah, good info....thanks.
I'll pursue that lead Cheers, Andy... Edinburgh, Scotland http://24heuer.com |
3rd Sep 2017 9:17pm |
Indeed not available from JLR at all. I tried my dealer, then our Swiss importer directly, then Dan at Duckworthparts, nobody could find a part number for this little clip. The BMW Mini version also is not exactly the same, but seems a close sister clip. So the genuine clips are rare as hens teeth, I can only suggest that if you have them, don't loose. I have one spare, securely stowed away.
Several here found this out the hard way as you can read below. Eric http://www.defender2.net/forum/topic15146....+dash+clip http://www.defender2.net/forum/topic51846....+dash+clip You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
4th Sep 2017 1:34am |
So, after a bit of googling it looks like the BMW/Mini part ref is 07131472727.
There are a few listed on eBay with that part # but the only UK one doesn't look as good as the others. I have a cousin who works for BMW so I'll give her a shout also. Interesting to see that other Puma owners are missing it too - bizarre! Thanks again for the super fast responses - much appreciated Cheers, Andy... Edinburgh, Scotland http://24heuer.com |
4th Sep 2017 8:06am |
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 |
Do you know anyone with a 3d printer?
4th Sep 2017 9:51am |
It'll only be a quid or something from BMW.
4th Sep 2017 11:14am |
Like the taking the car onto grass parking was justification for a steering guard I'm sure I could get SWMBO convinced I need a 3d printer to make a special run of these unicorn fastners
4th Sep 2017 11:30am |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 |
I have one!! ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
12th Sep 2017 7:38pm |
OK, so the BMW part number (07131472727) is correct and only cost a quid or so from local BMW/Mini stealers.
On the left is the new one and on the right is an original - identical Thanks all for the info Cheers, Andy... Edinburgh, Scotland http://24heuer.com |
13th Sep 2017 6:33am |
