Home > Wheels & Tyres > Bfg mud terrains...
Page 1 of 3 123>
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
Bfg mud terrains...
Well, Morocco booked up for the end of October & just getting the truck ready ( servicing pads ect) my bog standard Goodyear MTRs 235/85r16s are down to 7mm & by the time we go / get there they will be 5mm ish so time for a new set of shoes for the old girl. I'm thinking BFGs Mud terrains 235/85r16s ( have a spare with a nearly new one on so only have to get 4) The defender spends most of the time traveling off road, good choice given what we use it for or are there better options?
Post #648018 3rd Sep 2017 5:50pm
Go for 255/85/R16 KM2. Only slight steering lock stops adjustment needed.
No other issues than that, nicer than the 235's. $W33T $0U7H3RN $UG4R
Post #648028 3rd Sep 2017 6:35pm
Timcat
Thanks for the reply, why 255 rather than 235? Stops aren't a problem as we have 30mm spacers on.
Post #648036 3rd Sep 2017 7:03pm
Lodelaner
United Kingdom 1988 Defender 90 V8 Petrol ST Shire Blue
Why muds rather than AT's for Morocco? JB
@Lodelaner Instagram
Youtube greenlaning and other LR related content
Post #648039 3rd Sep 2017 7:23pm
Timcat
Well, apart from big trips ( Portugal/Morocco ect) most off road we do here & it's mainly mud thanks to our great weather. Do you still think all terrains?
Post #648041 3rd Sep 2017 7:29pm
Lodelaner
Fair enough - the pistes in Morocco are firm enough for any tire. Tyre pressures are perhaps a more significant factor. JB
Post #648042 3rd Sep 2017 7:31pm
Timcat
We are leaving Birmingham on the 27th of October so the weather in Morocco might be on the change? Have you done Morocco much? Any advice gladly received!
Post #648044 3rd Sep 2017 7:44pm
Lodelaner
Had a fab time there. I took ATs - but Mts are fine as long as you air down enough.
It's a mix of crappy tarmac, rocky pistes and sand. Side walls and construction are perhaps more important than tread?
Personally I'd take ATs. JB
Post #648048 3rd Sep 2017 7:48pm
255 will,have a wider footprint on soft ground and won't dig in as much. Plus a better ride. $W33T $0U7H3RN $UG4R
Post #648050 3rd Sep 2017 7:56pm
Lodelaner
I'd leave your 5mm GY MTRs on.
When you see the regular cars, vans and motorhomes zooming around you realise that you can overthink Morocco! JB
Post #648052 3rd Sep 2017 8:00pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
I would tend to agree about using 255/85/16 if you can get them.
The extra height under the diffs is appreciable when off road- I also appreciate the slight increase in gearing......
Chris
Post #648054 3rd Sep 2017 8:05pm
Timcat
So 255/85r16 on standard boost rims with 30mm spacers will work ok?
Post #648060 3rd Sep 2017 8:24pm
Yes, i don't see any problem with that.
You don't really even need any spacers, if you adjust the lock stops as I don't run spacers.
But I don't see any problem $W33T $0U7H3RN $UG4R
Post #648067 3rd Sep 2017 8:44pm
Timcat
All sounding good, what about rubbing on full articulation without a suspension lift?
Post #648078 3rd Sep 2017 9:06pm
There should be no rubbing, I'm running standard springs with spring isolators.
No rubbing issues. $W33T $0U7H3RN $UG4R
Post #648174 4th Sep 2017 10:37am
Page 1 of 3 123>
