Home > Puma (Tdci) > Starter motor problem developing?
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Started the 2011 2.4 110 XS Utility as usual (instantly on turning the key) this morning. Ran normaly for 40 miles or so, stopped for no more than 5 mins. Restart sounded like a dead battery and caught on second turn of the key, but only just. Drove for another 100 miles. 3 stops of 3 - 40 mins. and started normaly.
Had battery drop tested and it is in good condition.
Could this be the begining of a starter motor issue? - Or something else? Confused
Post #647639 1st Sep 2017 3:26pm
dorsetsmith
1. Check earthing terminal from battery to chases on transfer box
2. POS at battery
3. Starter relay
match more information below top marks Thumbs Up
Post #647647 1st Sep 2017 4:15pm
X4SKP
Hello shropshiredefender
I had similar symptoms early this year and chased the 'issue'
(spending money where it needn't have been spent... Embarassed )
I also have a 2.4 (late 2010 MY2011)
It may well be your Starter Motor...
How many miles... Question ...not an accurate indication of SM condition but a start
Before you start replacing anything significant...
Check all your connections...(everyone in the Starting Circuit) easy said, but when you actually come to do this it really takes time... All Power Feeds High and Low Voltage and All Earths.
Check the Starter Motor Relay...
(replacing this is next to no money so do this if you want and carry the old one as a spare).
No 3 is the Starter Relay...
After hours of work I traced my issue to the physical connection of the Red White Wire on the back of the Ignition Switch...which feeds Power back to the Starter Relay, you can hear this Relay 'click over' when working correctly (even with the seat in place) I then know she will start.
Starter Relay (R102)...
Through to Starter Motor...
Would be amazing if your issue was the same as mine, but really check the Ignition Switch connections are good...I cleaned the brass blade with 1000 wet and dry stuck to a needle file, tightened the push on connector added 1 drop of WD40 and reattached (with a more positive click into position)...all is now good.
My suspicion is as the blade and connector are dissimilar metals there may be some surface 'electrical corrosion' / or 'scaling' going on, probably on the Brass Blade of the Ignition Switch, anyway 100% this was my issue.
I finally sorted this after at times seeing (and testing) Red...
Good Luck... Thumbs Up SKIP
Post #647648 1st Sep 2017 4:16pm
shropshiredefender
Thanks chaps - checking all those items will keep me busy for the weekend! Bow down
Post #647651 1st Sep 2017 4:27pm
shropshiredefender
Its done 100.000 miles. The ignition switch was replaced last Jan. so I'll check that first!
Post #647653 1st Sep 2017 4:33pm
^^^^ Probably something mixed up with that as already suggested. Thumbs Up WeWillWin🇬🇧🇺🇸
⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #647675 1st Sep 2017 7:09pm
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
Just change the starter they are overworked and clog up with clutch dust. Signs are intermittent dead starter which will leave you stranded. You have had a longer life than most.
Post #647718 2nd Sep 2017 7:30am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Mine was doing the same, always started from cold, as soon as the engine was warm it would give symptoms of a flat battery, but would always start.
(It's a classic symptom)
As said above, the starters that are fitted to the Defender TDCI along with Peugeots, Fords etc are not the greatest starters in the world, and they do suffer with dust contamination badly.
If your going to replace it, get a decent Bosh unit. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #647725 2nd Sep 2017 8:56am
shropshiredefender
Thanks everyone. Thumbs Up
I spent Saturday tracing and cleaning connectionsand earth points, re seating and changing relays, and tightening the battery earth connection roughly 1/4 turn.
Could not replicate fault in around 20 starts, hot and cold.
However I will replace the starter motor before my next continental trip (with a Bosch unit). The original starter will be stripped cleaned and used as a spare.
At least I know that if / when it happens again all is OK up to the starter.
Post #647912 3rd Sep 2017 9:54am
zeroland
Australia 2008 Defender 110 Puma 2.4 SW Alpine White
Good timing on this post. Similar symptoms on my 110 however I find that the electronics seem to loose power as the starter motor engages and fails to start the motor. As a result, the trip meter resets to zero and my radio resets.
Got the local battery centre to test the battery and they claim it's still good.
Based on the above, could it be a simple fix like tightening up the earth or the starter motor is on the way out?
Post #648118 4th Sep 2017 5:38am
shropshiredefender
The starter is drawing too much current from the battery hence everythig else cuts out.
With luck it's a bad earth connection. So check battery earth, earth connections on transfer box and starter as suggested above. I gave then all a good cleaning and tightening as well, wire brush and WD40. Even if the earths are OK you will have done good preventative maintenance, as I should have done! Whistle
Be lucky Thumbs Up
Post #648247 4th Sep 2017 4:56pm
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
I had the similar issue with starter motor. Found the starter motor was dry with worn brushes. I replaced the brush kit and lubricated well with grease and all went right since then!
Post #648464 5th Sep 2017 5:34pm
zeroland
Thanks for the suggestions. Gave the earth connections a good clean and then plugged in the iCarSoft scanner to check if any symptoms were being logged. I did notice error P068A (Engine control module - power relay de-energised too early) was logged and after a bit of research people claimed starting issues when an ODBII device was permanently connected. I have an UltraGuage connected.
Since disconnecting the UltraGuage and cleaning the earth wires, no starter motor gremlins!
BTW, when the iCarSoft ODBII was connected and I started the engine, I got the Battery light and no movement in the rev needle.
Post #648926 8th Sep 2017 5:45am
X4SKP
zeroland wrote:
…after a bit of research people claimed starting issues when an ODBII device was permanently connected.
Interesting... Shocked can anyone add anything here... Question
Whilst 'chasing' my intermittent starting problem, I did a 'back to basics' electrical set up and test...various things providing security / monitoring were disconnected.
I also disconnect my ScanGaugeII which is otherwise permanently connected, I never thought that this may be an issue, and am convinced that it wasn't in my case, but I have never heard that it might be.
There is some comment (on-line) that the initial start up procedure with a Puma Defender can be 'interfered' with during the 'glow plug warm up stage' (until the light goes off), by doing something like operating the heater / fan / AC or as with a D2N member on here, the electric windows.
My Radio / CD / Sat Nav begins to come on before start up (second stage ignition) so I was aware of this also...disconnection and testing made no difference for me.
Maybe this 'electrical noise' (if that's the correct term) of some devices, could potentially cause a starting issues for some...
I'm 6 months and 6K miles post issue now with no problems (SGII connected throughout)
 SKIP
Post #648964 8th Sep 2017 9:48am
