Home > For Sale & Wanted > [Wanted] 61L axle case
under_rover
2002 Defender 110 Td5 SW Oslo Blue
I'm looking for a front axle casing for a 1995 90 should anyone around the Yorkshire Lancashire area have one kicking about that they're fed up of tripping over. Cheers
Post #647731 2nd Sep 2017 9:10am
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
I have a complete front axel was told it was off a 1990 its a 10spline free if you collect from Nottingham
Post #647741 2nd Sep 2017 10:54am
DSC-off
If it's the axle case in particular you want, then any similar age Defender, Discovery (pre td5) or classic Range Rover axle case would do. Just be sure to get one with ARB brackets if you need them.
I'm sure the basic axle case is the same for a similar age, it will be the build up of diffs, shafts, swivels,bearings and brakes that differs between models.
The radius arm brackets changed in the 1980's, to suit wider arms with bigger bushes, so check the gap is same as your current one.
Post #647747 2nd Sep 2017 12:26pm
under_rover
Thanks for all the info and offers.... Sourced one locally in the end up, so now sorted.... cheers Very Happy
Post #648296 4th Sep 2017 7:09pm
