Home > For Sale & Wanted > [Wanted] 61L axle case |
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 |
I have a complete front axel was told it was off a 1990 its a 10spline free if you collect from Nottingham
2nd Sep 2017 10:54am |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1410 |
If it's the axle case in particular you want, then any similar age Defender, Discovery (pre td5) or classic Range Rover axle case would do. Just be sure to get one with ARB brackets if you need them.
I'm sure the basic axle case is the same for a similar age, it will be the build up of diffs, shafts, swivels,bearings and brakes that differs between models. The radius arm brackets changed in the 1980's, to suit wider arms with bigger bushes, so check the gap is same as your current one. |
2nd Sep 2017 12:26pm |
under_rover Member Since: 02 Apr 2013 Location: Yorkshire Posts: 151 |
Thanks for all the info and offers.... Sourced one locally in the end up, so now sorted.... cheers
4th Sep 2017 7:09pm |
