Home > Maintenance & Modifications > Hazard Light Switch |
2 GOS Member Since: 03 Aug 2014 Location: Hertfordshire Posts: 66 |
Hi,
I am not sure if the bulb has gone or if it just does not have one. Can anyone tell me if the hazard light switch on a Puma should light up? TIA |
28th Jan 2017 7:20pm |
No expect it should yes. Mine has gone as well. Bulb you need is a T3 bulb. You can get traditional or led like these,
[url]https://www.ebay.co.uk/itm/152204726549 [/url] I will be getting these shortly. Looks odd at night without the switch illuminated... |
28th Jan 2017 7:50pm |
Maplins you can use these below
http://www.maplin.co.uk/p/12v-096w-wire-ended-filament-type-wq13p |
28th Jan 2017 8:52pm |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
This is the bulb for the Hazard Switch
Part Number : STC1205 Click image to enlarge Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
28th Jan 2017 10:44pm |
Cheers, bulb ordered.
29th Jan 2017 5:53pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
thanks guys....can you get the switch out without removing the dash?
2nd Sep 2017 7:44am |
