![]() | Home > Td5 > Rear brake disc - minimum thickness |
For the expense, I'd probably get them replaced if you're concerned. Peace of mind too.
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5890 ![]() ![]() ![]() |
I am leaning towards replacing them. Since I got the car they have done nearly 60k miles.
The replacement option, opens the debate. Standard or grooved discs. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2709 ![]() ![]() |
Standard every time.
On the rear, standard is fine, grooved for 'looks'. I'd dare say you'd not tell a difference. At all.
Cheers - I think standard it will be. 1999 Defender TD5 110
Oh you'll notice a difference - the horrible screech of metal-on-metal as the rear pads wear out a few thousand miles after going anywhere remotely muddy.
As intimated above, they're of no use. Drilled/grooved brake discs are for 17-year olds to attract birds in McDonalds car parks. |
*like*
![]() Regards John M0VAZ Econet Station 48 no clock |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 ![]() ![]() |
i'm off to Halfords; followed by a trip to McDonalds...
I'm chav'n it ! 1999 Defender TD5 110
IIRC minimum thickness for the rear brake discs is 10mm not incl the lip. looking to replace mine in the next month or so. they are britpart drilled and grooved (mated to green stuff pads) and have done stella work over the past 5 years. love them to bits. ![]() ![]() |
I think with the lip removed I am towards 8mm thick. TBH, I think I will be sticking with standard discs along with new pads and fresh fluid with a decent bleed through they will be good again 1999 Defender TD5 110
