Home > Td5 > Rear brake disc - minimum thickness
excossack
On checking the rear brake discs, they are down to 10/11mm thick (with a lip)
What is the minimum thickness that is suggested? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #647037 29th Aug 2017 7:23pm
For the expense, I'd probably get them replaced if you're concerned. Peace of mind too.
Post #647039 29th Aug 2017 7:25pm
excossack
I am leaning towards replacing them. Since I got the car they have done nearly 60k miles.
The replacement option, opens the debate. Standard or grooved discs. 1999 Defender TD5 110
Regards
John M0VAZ
Post #647041 29th Aug 2017 7:27pm
Retroanaconda
Standard every time.
Post #647047 29th Aug 2017 7:42pm
On the rear, standard is fine, grooved for 'looks'. I'd dare say you'd not tell a difference. At all.
Post #647054 29th Aug 2017 8:22pm
excossack
Cheers - I think standard it will be. 1999 Defender TD5 110
Regards
John M0VAZ
Post #647062 29th Aug 2017 8:42pm
Retroanaconda
Oh you'll notice a difference - the horrible screech of metal-on-metal as the rear pads wear out a few thousand miles after going anywhere remotely muddy.
As intimated above, they're of no use. Drilled/grooved brake discs are for 17-year olds to attract birds in McDonalds car parks.
Post #647069 29th Aug 2017 8:58pm
excossack
*like* Rolling with laughter 1999 Defender TD5 110
Regards
John M0VAZ
Post #647070 29th Aug 2017 9:03pm
V8GPC
i'm off to Halfords; followed by a trip to McDonalds... Razz
Post #647100 30th Aug 2017 6:03am
excossack
I'm chav'n it ! 1999 Defender TD5 110
Regards
John M0VAZ
Post #647116 30th Aug 2017 7:56am
geobloke
Re: Rear brake disc - minimum thickness
IIRC minimum thickness for the rear brake discs is 10mm not incl the lip. looking to replace mine in the next month or so. they are britpart drilled and grooved (mated to green stuff pads) and have done stella work over the past 5 years. love them to bits. Thumbs Up Thumbs Up
Post #649449 10th Sep 2017 8:23pm
excossack
I think with the lip removed I am towards 8mm thick. TBH, I think I will be sticking with standard discs along with new pads and fresh fluid with a decent bleed through they will be good again 1999 Defender TD5 110
Regards
John M0VAZ
Post #649571 11th Sep 2017 12:35pm
