![]() | Home > Technical > 110 Puma P38 rear diff. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6138 ![]() ![]() ![]() |
It's part # 561196
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2709 ![]() ![]() |
Do you mean the nuts that hold the diff carrier into the axle casing? If so they're just standard 3/8" UNF nyloc nuts.
The crown wheel is inside the diff and I can't see how you would be in there just fitting a guard on? |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 923 ![]() ![]() ![]() |
NY606042
are the nuts that that hold the diff in. |
Timcat Member Since: 20 Jul 2016 Location: Rugby at the moment Posts: 1025 ![]() ![]() ![]() |
Sorry for the incorrect terminology, there's 10 studs that come out of the diff casing that attach to the prop ( which In turn secure the wild bear diff guard three at the bottom & two on the top)
