Home > Technical > Aschroft half shaft with HD Paddock drive flange problem
Itox
Croatia 2007 Defender 90 Puma 2.4 CSW Alaska White
Hi,
If there's a topic like this I apologise as I've not found it, but I really need help of people with experience and I hope to find it here.
I've recently purchased new Ashcroft half-splines for my defender PUMA 90. (rear ones) and to make stronger, I've also purchased new paddock spares heavy duty drive flanges to use instead of stock ones.
Now.. I see that the ashcroft doesn't have lock ring on the inner side of outer gear, but normally it does have a place for lock ring on the outside of gear - the drive flange lock.
Simply, by measuring and by checking (trying to mount the drive flange both ways, correct and wrong (inside-out to better see the remaining space)), I've seen that the drive flange is too fat, and the place to put lock ring to block drive flange doesn't exit the drive flange..
Please have a look on all my pics, and let me know what to do. Is the Ashcroft half-spline not compatible with stock/paddock spares drive flanges?
Thanks a lot!
Post #646311 25th Aug 2017 5:44pm
Itox
Post #646312 25th Aug 2017 5:46pm
Devon-Rover
Those flanges look a little think they are the PM770's? not the PM769's right?
Post #646316 25th Aug 2017 6:08pm
Itox
They are PM769, is that the right one?
Post #646320 25th Aug 2017 6:32pm
Devon-Rover
There are two styles of drive flange used on the Defender. The thick style used up to about 1993, then onwards there is the thin style.
The PM669 is the HD version for the thick flanges the PM770 is the HD version for the thin flanges.
You have a puma so will need the thin style flange QED the PM770
Hope this helps Thumbs Up
Post #646326 25th Aug 2017 6:58pm
Why not use Ashcroft HD flanges, guaranteed to work with Ashcroft HD shafts?
Post #646365 25th Aug 2017 9:40pm
SteveT247
England 2002 Defender 90 Td5 XS CSW Bonatti Grey
As others have said, you need the thinner drive flanges. Mine (below) are Ashcroft but one of my mates has been running the Paddock ones with Ashcroft shafts for the last few years with no problems.
Post #646392 26th Aug 2017 9:25am
Itox
Thanks everyone, I will try to replace them by Paddock.
Post #646393 26th Aug 2017 9:26am
Naks
apologies for the n00b question: why would one fit these drive flanges as opposed to the LR ones? --
Post #646403 26th Aug 2017 10:34am
They're better made, stronger, and last longer.
Post #646408 26th Aug 2017 10:54am
SteveT247
According to Steve @ Crown Diffs, Ashcroft shafts will also accelerate the wear on standard LR drive flanges due to the difference in hardness between the drive flanges and the shafts.
Post #646417 26th Aug 2017 12:21pm
ickle
Daft question, but as the flanges are thicker, could a few mm be turned off the outside to allow the circlips to fit?
(as the OP seems to be abroad and with postage etc may be more trouble than getting them spun down in a machine shop)
Post #646443 26th Aug 2017 3:33pm
SteveT247
I'm not sure you could as there is a rim/lip on them.
Post #646453 26th Aug 2017 4:53pm
bankz5152
Tbh I would still use standard flanges, they end up being the point of failure as well as being cheap and easy to change.
Much better to break a £10 flange and change it in 10 mins or blow a diff instead...
Post #646464 26th Aug 2017 6:22pm
Pickles
I think I've read on this forum that there can be difficulties with these heavy duty flanges etc when fitting them with Dual Finish/SVX alloys on a Puma in that the larger "fittings" will not fit under the standard Landrover centre wheel cap on these wheels?
Pickles.
Post #646492 26th Aug 2017 9:17pm
