Home > Maintenance & Modifications > Relay inside battery box...or better not? |
Nope. The relay for the standard Land Rover towing electrics loom is located in the battery box. Darren
20th Aug 2017 9:17pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2411 |
Is that right? Mine is a LHD and I'm pretty much sure I have not seen it. Puma 110" SW
20th Aug 2017 9:19pm |
It was on the TD5 that I last installed and is on my current 200tdi. Both are RHD though, so maybe the layout is different. Darren
20th Aug 2017 9:21pm |
Ok. Anyway, some have relays inside the battery compartment.
Puma 110" SW ............................................................. Earth first. Other planets later |
20th Aug 2017 9:23pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
No problems at all, calling the battery box sealed is optimistic at best!
20th Aug 2017 9:35pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello MK
LandRoverAnorak is right, the recommended location for the LR OEM 13Pin Towing Electrics Relay is within the Battery Compartment... (this is my Puma 2.4) Click image to enlarge Click image to enlarge I would say Low or No Risk at all, if the correct Relay and Loadings are in place... (avoid any cheap 'sub-standard' electrics ) SKIP https://www.defender2.net/forum/topic83242.html |
21st Aug 2017 9:13am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17346 |
The standard battery is vented via a pipe running out through the floor of the compartment (at least is it on my 2007 Defender).
21st Aug 2017 10:17am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20294 |
^^^^ This is true, there is no issue at all.
Definitely use quality branded wiring and Relay though. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
21st Aug 2017 11:07am |
Thanks all for the answers. Puma 110" SW
21st Aug 2017 11:33am |
