Home > Maintenance & Modifications > Relay inside battery box...or better not?
MK
Any chances relays (eg. auxiliary lights) would produce sparks inside this semi-confined box? Puma 110" SW
Post #645314 20th Aug 2017 9:08pm
Nope. The relay for the standard Land Rover towing electrics loom is located in the battery box. Darren
Post #645319 20th Aug 2017 9:17pm
MK
Is that right? Mine is a LHD and I'm pretty much sure I have not seen it. Puma 110" SW
Post #645321 20th Aug 2017 9:19pm
It was on the TD5 that I last installed and is on my current 200tdi. Both are RHD though, so maybe the layout is different. Darren
Post #645322 20th Aug 2017 9:21pm
MK
Ok. Anyway, some have relays inside the battery compartment.
Thumbs Up Puma 110" SW
Post #645323 20th Aug 2017 9:23pm
miker
No problems at all, calling the battery box sealed is optimistic at best! Laughing
Post #645326 20th Aug 2017 9:35pm
X4SKP
Hello MK
LandRoverAnorak is right, the recommended location for the LR OEM 13Pin Towing Electrics Relay
is within the Battery Compartment... (this is my Puma 2.4)
I would say Low or No Risk at all, if the correct Relay and Loadings are in place...
(avoid any cheap 'sub-standard' electrics Shocked ) SKIP
Post #645369 21st Aug 2017 9:13am
The standard battery is vented via a pipe running out through the floor of the compartment (at least is it on my 2007 Defender).
Post #645386 21st Aug 2017 10:17am
^^^^ This is true, there is no issue at all.
Definitely use quality branded wiring and Relay though. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #645401 21st Aug 2017 11:07am
MK
Thanks all for the answers. Puma 110" SW
Post #645407 21st Aug 2017 11:33am
