![]() | Home > Td5 > Td5 90 with fuel tank guard? |
Don't know if this helps as it relates to a 110, I removed the thin plate LR tank guard when I fitted the thick after market tank guard 130's have feeling's as well you know
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2662 ![]() ![]() ![]() |
Hi
I have one and bolted it over the original plate so would agree with your suggestion. Mark |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 ![]() ![]() ![]() |
I fitted a Safari Equip one recently. Just fitted it over the original thin one, by removing and refitting some of the bolts. Can't see it being a problem, not having the thin original one in place.
Steve ![]() Discovery 3 HSE BMW 330i Coupe |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6163 ![]() ![]() ![]() |
OK, thanks all for the replies.
![]() ![]() ![]() Next question... does the tank "sit" on the thin guard? or is it just that.... a guard? If the thin guard is removed, will the tank then "sit" on the new HD guard, or is it supported by other brackets? sorry for all the Q's! ![]() ![]() |
I can only talk for the Safari Guard.
Mine sat on the lower side of factory fit guard and supports. From memory I took the 3 large bolts out from each side and the guard is drilled for the same holes. What I found confusing was the large size of the pre-drilled holes, but as it turned out you are supposed to fit with large washers circa 1" which actually works fine. Sorry, not answering the question........ Tank does sit on the thin guard and will need supporting, but as it is so thin, I would assume the tank can be supported on the new guard without any probs - would lower tank approx 5 mm. Steve ![]() Discovery 3 HSE BMW 330i Coupe |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 ![]() ![]() ![]() |
would a tank guard fit with the drop tow bar assembly? 2004 TD5 Defender 90 xs station wagon
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
mine sits on the guard |
Evenin' Marcus You say yours sits on the guard... which? your aftermarket HD one, or the factory thin tin plate? |
on the tank guard, took the flimsy factory on off as it won't protect the tank and it drops the tank down a few mm which helps if you have to change the pump or drop the tank.
do you need the factory flimsy bit? |
Will need a flimsy guard until i get a decent one.
mind you, got to a) get my chassis yet, b) fit a Td5 crossmember to it, c) make/buy/weld on some Td5 tank brackets! ![]() ![]() |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2691 ![]() ![]() |
2 days till chassis time!!
![]() 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
/evil James Bond henchman voice/
....2 days..... and counting....... |
as always i'll offer my services but looks like the doozers got it covered |
Doozer
![]() ![]() ![]() I've got a MIG here, and can manage to stick some bits of metal together... just. |
