Home > Maintenance & Modifications > Hinge bolts.....? |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 |
Yes there is and Google is your friend.
15th Aug 2017 7:57pm |
V8Smith Member Since: 18 Apr 2017 Location: Cuckfield Posts: 22 |
Thanks yes I found some, but thought I'd ask as I'm sure there are differing degrees of quality, so any recommendations welcome
Regards Mike |
15th Aug 2017 8:00pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3641 |
Nak are reputedly the best, speak to Brendan at Overlander.com a sponsor of this site alternatively spray you existing bolts occasionally with ACF50 DEFENDER 90 TDCI XS,
15th Aug 2017 8:06pm |
Buy new mild steel genuine bolts.
Take old rusty out one at the time. Clean hole well with a thin paint brush first dipped in Weicon paste. Replace by a new genuine mild steel bolt dipped in ample Weicon paste. Any remaining genuine mild steel bolts which are still rust free, also take them out, dip in Weicon paste, and put back. If you do a search on here with the words "original mild steel bolts Weicon paste" you will get more info. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
15th Aug 2017 8:17pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20347 |
Are we talking the Torx bolts here or the hinge pins? $W33T $0U7H3RN $UG4R
15th Aug 2017 8:25pm |
Mike said bolts, hence my recommendation. But if he means rusty hinge pins, I have a different perfect solution to solve once and for all.
This one.... http://www.defender2.net/forum/topic55937.html A bit more costly than new mild steel bolts regretfully. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
15th Aug 2017 8:40pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
The Nakatanenga stainless bolt kits are the most comprehensive available in the UK market.
The door bolts are the genuine shape heads. We hear that when people use google and various market places for non genuine headed door bolts sometimes they have to be reshaped! The stainless bolt kits from Nakatanenga come with anti seize paste as standard which other UK suppliers do not supply. Available as naked stainless or black stainless. Brendan |
16th Aug 2017 8:01am |
^^^^ Very very good too, often corroding OE bolts are a let down to look at on an otherwise brilliant looking Defender.
Had my Nak SS bolt kit fitted fir a while now and no issues at all. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
16th Aug 2017 10:34am |
Thanks guys, will order the Nak bolt kit from Overlander today, thanks for the advice.
Sorry for the stupid question, but as a Landy novice, is it just a case of removing each bolt one by one and replacing with the new one of the same length etc, or is there a nut inside the car I need to locate too? Cheers Mike |
16th Aug 2017 4:29pm |
Most of them have captive nuts, those that don't are on the doors themselves and are pretty easily accessible.
Just do one by one. You won't have any issues, easy bolt fit. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
16th Aug 2017 5:13pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5110 |
Depends if the captive nuts are in good condition but often the mild steel cradle they sit will have rusted and taking the bolt out breaks the cradle or more often than not they move. In which case you will have to remove both bolts and pull the hinge away to either resit the captives or replace, still an easy job though. If you have to replace the caoptives order stainless steel ones so you will not have any problems in the future. Click image to enlarge For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
16th Aug 2017 5:48pm |
